Recommendations for a beginner
A compressor is the way to go. I found mine on eBay for a song and has lasted for years. The one thing that will help is a moisture trap.
As far as paint there are 3 major groups.
Lacquers: They are the best at adhering to the plastic or primer and spray like a dream but brush terrible. Most toxic in the air.
Enamels: They adhere well to the plastic or primer, spray well and brush OK. Medium toxicity in the air. You will need to experiment with the thinner mixture to spay to your liking
Acrylics: So-so at adhesion, harder to spray (there are pre-mixed acrylics that spray better) brush well. Least toxic. Acrylics tend to “tip dry”. This is where the paint dries as it leaves the tip on the airbrush. There are retarders to help with this. Like enamels, the thinner mix is dependent to your liking.
The last group would be the metallizers. Typically, lacquers, they will look like metal if applied correctly but will require a good prep and usually a base coat.
To thin any of the above paints always use the manufactures thinner. They formulated it, they know how to thin it.
Good place to start is on Youtube. Loads of instructional videos that show you almost everything about the hobby, except the patience part.
My only advice (kind of a newby myself), don’t buy a $25 AB from China. I had $25 left over on an Amazon gift card and bought one. Destroyed .2mm and .35mm needles in first month, I swear, just by cleaning the tips. Nozzle caps will break quite easily,also. The reviews sound great but…on the positive, quick connect and the “trigger contol” thingy fits my NEO perfectly. I agree with GoldHammer, go online with HobbyLobby and pick up a NEO for $50 with coupon and get it shipped to your house. Do you have access to any air compressor at all? If so, use that…
I agree with this thoroughly. Revell/Monogram and Airfix put out reasonable quality at reasonable prices. The fit is usually good, an important feature for a beginner. Bad fits can be fixed, but you have to know how.
Tamiya has super quality, with super fit and super detail. But the prices are high, as is the parts count. While a high parts count gives better detail, it can be overwhelming to a novice. The detail of Airfix and R/M kits are not bad, but not as good as Tamiya (this is changing- both of these companies are using new molding technoloties that give super detail). For now, you need reasonable detail and good fit so that the model comes out okay. The higher detailed kits can come later.
I would recommend staying away from Eastern European kits. The fit on many of them are problematic, and I have trashed several of them, even with seventy years of model building experience.
Lol, hate to be a jerk and (sorta) disagree with you GM but though the Academy 1/72nd B-17s are fine kits the newer Revell of Germany is hands down better in every way. And in the current issue of FSM the review of the new Airfix kit makes it seem even better yet.
I don’t think I’ve seen it mentioned Tamiya’s 1/48th F4U Corsair. A bit out of what you listed as your interests but the kit is a gem. Fit that can’t be beat, it’s a ‘insert X-excto knife and tube of cement in the box, shake, and it assembles itself’ kit. Plus you can often find it for about twenty-five bucks US.
Thanks, modelcrazy
So I’ve been watching some youtube videos for airbrush beginners and something a lot of people recommend is either buying or making a spray booth. I plan on working in my basement so I don’t really have any windows or anything to ventilate out of.
So what if I just bought a mask of some sort? Would a dust mask work or would it need to be like a Breaking Bad-style respirator?
Also, if I just did paint work in my backyard would that solve the problem too?
Thanks again
A dust mask works for me but I also open a window with a fan. Painting outside works great until a wind blows up, the temperature is below 60ish or the humidity is too high.
If you use acrylics the fume and toxicity problem is cut way down. Someone else may have a solution for you, but I would think there is a way of venting the exhaust into some sort of filter.
See what you can rig up. Rven one of those ductless kitchen hoods with a filter is better than nothing.
Cats have really tiny lungs.
I have a fan insert for a window . I modified it with a sparkless blower to vent my paint booth outside .They are available at any Home Depot .Oh, Hi too ! Another thing for A newbie I would definitely recommend Tamiya or Hasegawa .Especially Tamiya’s P-47 " Bubbletop ". Best model plane I’ve seen lately . T.B.
I painted My C7R with a testor’s rattle can I got from Hobby Lobby on clearance for about $2.50. Best paint job I’ve done. If you want to go that route. I use both the airbrush and rattle cans and enjoy both. Also on the C7R from Revell, the instructions don’t say so but the bottom of the body needs to be painted Gloss Black. I found that out too late. I had already put decals on when I noticed it on the box. I thought dummy how’d you miss that. When I when back to the instructions, I couldn’t find where it said to mask it off and paint it black. Another tip, read all of the instructions really good and look at the box, if you are going with that paint scheme. Also, any parts that can be glued together and painted the same color, blue them together before painting. Have fun.
Who cares if you forgot to paint the bottom side. You’re not gonna see it when you display it anyway. LOL!
Not the chassis, it was the bottom 4th of the body.
Go with a resperator. A dusk mask is not enough. Resperator filters last a lot longer for modelers since we are not spraying gallons of paint. If you have a floor drain in your basement, you can run a spray booth vent tube into the drain.
I have been airbrushing for over 20 years and my first airbrush was a paasche H. I still have it and still use it even though I now have 4 other airbrushes that are a lot more expensive then the paasche. This is just personal opinion and other name brand starter airbrushes I am sure are just as good.
As others have mentioned, don’t get a Chinese airbrush. You will get frustrated and ruin all your hard work. Chinese brushes do not smooth out the needle and fit and finish on the internals are bad. The seals are usually weak and you end up with nothing but problems.
Join a local model group and ask some of the members their experience. Some of them may even let you try their setup. I have let new modelers come and try my setup so they can make a decision.
95% of the paint I use is Acrylic so I just go with the dust mask. I spray outdoors when I use enamels or lacquers but that is a good tip about getting a respirator.
Welcome to the hobby! As someone who started the hobby on the poor side of life, don’t start stocking up on expensive toys and tools until you’re sure you want to make that investment. I’ve found there are a lot of everyday things that can be multi-purposed into modeling tools. Here’s my poor man’s guide to getting started. And keep in mind, this is the starter kit. You’ll start expanding soon.
Sprue cutters: Eventually you’ll want to get these, but in the interim, use a nail clippers. I still keep a new nail clipper on my workbench. It gets a close cut to the part without gouging the plastic, it is great on smaller parts, and is effective in trimming little bits of excess plastic or small flash.
Sandpaper: You can get model specific sandpaper, but I prefer a home improvement store for coarse grits and an auto parts store for finer grits. Get a sanding sponge (the thin flat kind in a) while you’re there. It allows a lot of flexibility in sanding different shapes. And wet sand as often as you can. It makes things go smoother.
Hobby knife: Here’s where I recommend you fork out a little extra and get one that will take a replaceable #11 blade. Don’t buy the model company no-replacement blade knives; they wear out way too quickly. The #11 blade knives are great for shaving parts, removing flash, cutting out decals, and even cutting parts from the sprue. You want to replace the blades when they get dull … which happens much quicker than you’d think.
Glue: Have plastic glue and super glue (cyanoacrylate / CA). Liquid glue is worth the investment as it is easier to use and not as messy. But get a brush to go with it, a thin brush. A thicker brush will end up putting too much glue into a seam and it will leak out the other side (so I’ve heard ). I use an old sable brush that I retired from painting. For CA, when you’re at your local discount store, pick up a container of thick and thin. Go with a more known brand (I prefer Loc-Tite for my cheaper glues).
Clamps: I recommend ye olde clothespin for clamping. It doesn’t put too much pressure and gets the job done. If necessary use an old rag or paper towel to protect any finish that may have been pre-applied.
Stirrers: Get a box of wooden coffee stirrers on Amazon to stir your paints. Don’t shake them …. it’s a hard habit to break and usually leads to me needing to use pliers and wrenches to open a jar of paint. They can also be used in applying putty. Eventually, invest in a mechanical paint mixer. It’s great on paints you haven’t used in a while.
Misc. tools: Check out the health and beauty aids section of the local store. Lots of things can be found that are very useful. Totally unrelated side note: I found a cuticle tool in the nail care section that works great in scraping out vanilla beans when making crème brulee.
Work mat: If you need a cutting surface, get a scrap booking mat (AKA self healing craft mat). I picked up three at a thrift store a while back. It will protect your work surface and if you get paint on it, it’s no big deal. Use the light colored side if you kit has dark parts, the dark colored side (usually green) for light parts. This will prevent parts from getting “lost” on the table. If you don’t want to get a mat right now (you may not really need it), I do recommend getting a sheet of neon colored poster board. It’s cheap, it protects your work surface, and it’s great for keeping parts from getting lost on the work table.
Paint brushes: Do not use the model brushes (Testors, I’m looking at you). Period. Look for a pack of sable brushes (they usually run $5-$10 in the States) at a craft store. That will give you various thicknesses and put on a much better coat than the hobby brushes.
Paint stand: Most times you’ll need something to put your model on when you paint it. You can spend $25 on a name brand paint stand (which will be well worth the price later), but in the interim, there is a cheaper and very flexible solution. Get a coat hanger, unravel it so you have a long wire, then bend it into a free standing holder. You can also bend it into a U shape and mount it an a small piece of scrap 2x4 lumber for a more stable stand (best for cars, but will do a lot more than that). The hanger allows you to shape the stand to fit the model.
Excellent advice Jammer. This is exactly how i started and am still employing some of these tips namely because I’m cheap.
Yep those cheap thin metal shirt hangers are great to hold parts for painting things like a plane for example. I cut it to the length I need and if a twin jet engine as an example, I make a Y and run it up into the engine area and paint away.
Also the Dollar Store and places like Walmart and Target have lots of thingies to use like padded multi grit sanding sticks, Q Tips, nail clippers, cheap hair spray (for weathering) , Flores wire (for detailing pits and engines) , and so much more.
Harbor Freight has some decent tweezer sets along with a brush cleaning set for air brushes. Speaking of Harbor Freight please stay away from the cheap Chinese air brushes. They may work for a while but you are better off with an entry level Badger or Paashe that will not break the bank.
