Hello all. This is the first time I’ve posted in the airbrush forum in awhile. I’m thinking about a new airbrush and I need some advice (or rather just somebody to just tell me to go ahead and do it [:D][:p])
My Badger Crescendo and Badger 150 have served me well and will continue to be my workhorses but I need one with a litte bit finer abilities. I model mostly 1/72 everything but I’m not limited to that. Among other things, I’m mostly concerned with finer camo lines, pre-shading small panel lines, hitting small details like lamps/taillights, weathering touches, and of coarse the pinacle of airbrushing - the German style worm and splotch camo. Here are the ones I’m considering, they all have built in small gravity feed cups:
I’m not trying to make this a poll or popularity contest. I know the Iwata rocks, but I’m really leaning strongly towards the Omni or Badger 360. Sorry such a long post. TIA for any input.
I just bought the Paache for the same reason. Am experimenting with pressures. Paache seems to reccommend higher PSIs than I’m used to. Good buy at DixieArt…2 cups, 2 needle assemblies, brush, and hose with fittings. $62.95, shipping included. Will post later on my conclusions as to pressures. Just want to say that I’ve learned almost all I know about airbrushing right here on the Forums. Thanks all you ABers.
The Paasche VJR has the smallest cup of all of those. It is excellent for one thing I’ve found so far… when you have to touch up tiny areas with enamel. I usually only use its no. 2 nozzle (the bigger of the two). With acrylics, there’s too much tip dry going on with this airbrush. It’s not a multi-duty airbrush, but it does handle tight enamel jobs that the Omni 5000 just sprays a little too big for.
I use the Omni 5000 for everything else. Even though it’s the small cup model of the Omnis, its cup is quite deep. It goes all the way down into the body cylinder. You really can cover a lot of area if you fill that cup all the way up. It is capable of very fine lines. It’s just not as easy to pinpoint what I’ve got to hit like the VJR does.
If I had the Badger 100, I’d probably be telling you that it does what both of these airbrushes are capable of. That’s just my guess. I’ll have one of those some day too.
I would say the Badger 100G or LG would be capable of the finest lines out of the Badger choices and is in the same category as the Iwata HP-B.
The 100LG also has a cover for the color cup which the 100G does not have.
The Omni’s are also great as is the 360, but I would opt for the Omni 5000 (I prefer the 4000) over the 360 for your needs.
