I keep seeing photos of modern landing gear where the gear is white but there are little touches of black in there as well. What kind of technique can i use to achieve this?
Usually a pin wash in all the recesses will get the detail on the landing gear to pop out. After the base colors are applied and fully dry of course. Struts, oleos, brake lines, and tires…
To add to what Stik said about pin-washes (Meaning, “Pin-point” washes), the trick is not using pure white as a base color, because if you do, you got nowhere to go but darker. So when white is called for, take your white and add a skoshi-bit of black to it. VERY little…
Frankly, I like to use Testor’s Model Master Camouflage Gray (# 1933, FS 36622) instead of pure white. It’s about as light a gray you can get. Then you can add some black (Always add much less than you think is enough) to it to darken it as a wash in the recesses, and use pure white to drybrush highlighted areas. Sometimes, dirty thinner is enough…
Add Steel where needed like on the scissors and bright silver to the Oleo-legs…
Honestly, I never use straight white on a vehicle unless it’s a special thing. I use light gray out of the bottle, wash with a brownish color, and drybrush with straight white. Plus gray usually covers better, white has a tendency to be translucent.
I use a little strip of tin foil on the oleo leg…
I use MV lenses from model railroads if it has a landing light/ taxi light.
