railway diorama idea
I would like to build a diorama of German Panthers unloading from railcars. I have built s boxcar and I would like to put that at the end of the train maybe having infantry unload from it. There would be 2 panther railcars and maybe some side traffic or an entenched 88. So what do you guys think?
Sounds like an excellent idea Tankluver, what scale would you build this in?
The Squadron-Signal publication Tiger In Action shows Tigers being unloaded from the flat cars you are referencing, shows the travel tracks and installation of the road tracks, and lists dimensions of the flat cars. The same flat car was used for transporting Panthers and IVs.
I like the idea of your diorama, but two or three flat cars, plus a box car, and an emplaced 88 in 1/35th scale will be a very large display. You might want to consider making it in two or three pieces.
I was going to build this in 1/35
EasyMike is right Tankluver, you should definately build it in sections so that it can be stored/moved easily. Something as busy as what you’re planning will take some space! Can’t wait to see it.
rb
From an old railhead-
Anything having to do with model railroad track is not to scale, esp. in the largerish ones, until recently. A scale dio of a switch and a siding needs 50 meters before the tracks come back to parallel on a mainline, which is where you’d be. That means 1.5 meters at 1/35 scale. Now you have the two lines side by side. And build from there. Not good.
At such a large scale, (edit- mine is 1:160), I’d take advantage of the scale to have a big width, like four tracks, but all parallel front to back. This suggests a major marshalling/ shunting/ switching yard without the necessary geometry of switches.
If rails are spaced 4 meters apart, 16 meters total at 1/35 equals 1/2 meterish.
Your two flats plus equal room to unload are 60 meters total, or a little less than two m at scale. Lose the van/ box.
EDIT: thoughtless comment for which I apologize. Put it on a separate parallel track.
So your dio should be 50 cm by 150 cm, or 24 inches by 72 inches. The only scale euro rail I’ve liked at 1/35 is Verlinden, which will cost you the Queen’s ransom.
But rail is really easy to scratch if there are no hardware or radius issues. I think I’ve said before that ties (sleepers) at 1/35 should be about 1/4" wide. You can buy rail from various sources, or just use a piece of strip with a top cap.
Make it all more or less the same brown color. I use pollyscale “tie brown”. Not rusty.
Lots of weeds- the track maint. guys were in the army and doing other things.
That old stanby the 80" by 30" hollow plywood door from Home Despots will serve you well here, and give you enough width to run the tracks across at an angle, w/ the armor on one side so that it’s unloading won’t rip everything up. You could stick a few minor things over on the other tracks, too.
Bill
Tankluver, I have done a similar project recently. As an armor guy and a rail enthusiast I will go on record that it was a fun project, combining both hobby interests. I chose O scale rail to partner with 1/48 armor. It didn’t take up too much room on the display shelf. I’m enclosing a picture, the setting is WWII US 2nd Armored Division returning from the Carolina Maneuvers prior to shipping overseas. Perhaps it may help as you put your ideas in action.
