And if you happen to have a wiring diagram…[whstl]
I hope wbill will come to your rescue… with a wiring diagram! [:D]
All I GOT is this.
I saw one just this morning online and for the life of me I can’t remember where it was. I was going to save it for myself and my PC went down. It showed the whole set up with the headset and several different wires on the front.
This is the wiring diagram for a full-on Marder II radio arrangement, however a standard Marder III M wouldn’t have had both the sender and receiver, just the receiver. Only the command versions had both.
An accurate representation of the wiring is how I rigged up mine when I built it back in 2007, might help you out as well.
Thanks boys…that works. I really need to learn how to search better. But I was in a total fog last night. If I had gone out I might not have found my house.[whstl]
This helps me out as well as I am building a Marder III.
Bill what is the box directly above the shells on the left? Is the little “nub” on the top a base for an antenna? or where would the antenna go?
Thanks for the image and diagram!!
The antenna on the Marder III-M mounted on the exterior of the fighting compartment armor plate. What you are seeing is the small junction box that the antenna cable connected into. HTH!
Good stuff!
I’ve got the Dragon Marder III Ausf M Command Vehicle in my stash and I know that getting the wiring rigged up correctly is going to be play a big part in this build so I’ll be following this thread very closely.
Thread bookmarked!
ATVB
Ben [H]
