Radial Engines
Hi not sure if this goes here or not but i’m looking to build a lancaster and halifax in 1:72 and can not seem to find aftermarket radial engines Both the aircraft i looking to build need them.
any help would be gladly recieved.
Thanks
Lancaster bombers used 4 of the Merlin V-12, liquid cooled engines, the same as the famous Spitfire. The B-I and B-II Halifax bombers used 4 Merlins also. The Halifax B-III version used the Hercules radial engine.
Darwin, O.F. [aln]
http://airfixtributeforum.myfastforum.org/archive/atf-fourth-anniversary-gb-ratch-s-lancaster-mk.ii-build__o_t__t_18402.html
This may be of interest.
Might try looking farther than after-market engines for a Halifax… The Beaufighter used the Herc Radial as well, so you may want to expand your search parameters to include Beaufighter engines…
Thanks just looked up paragons site and the sets sold out i forgot about the beaut.
Look for the specific engine model, not the type aircraft it was used on. Pratt & Witney R2800 or Bristol Hercules as examples.
Radial engines were primarily used on such RAF bomber as the Sterling, Wellington and Halifax.
Only 300 Lancaster IIs were built with 1,650 hp Bristol Hercules VI radial engines.
http://www.aviation-history.com/avro/683.html
Hence the lancaster b mk II
2 squadrons that i know of where equipped with this bombers in the RCAF
