When using images as part of a hyperlink in one’s sig, why doesn’t the cursor change to the pointing finger-thingy when it passes over said images[?]
Fade to Black…
Fade to Black…
It only appears on the images which have been forced to display smaller than they really are. It’s supposed to help indicate the image is clickable (to view the full size).
Example…
Image #1 is 70 pixels wide x 50 pixels high.
Image #2 is 480 pixels wide x 348 pixels high. Because it’s width is greater than 350 pixels, there’s a javascript function which tells the browser to display it as 350 x 254 instead of it’s original dimensions. Although the dimensions within the browser has been changed, the actual file size has not changed.
Did I lose anyone – show of hands if you’re still confused. [;)]
Thats a good looking Lightning there David. Did you build it?
I wish!
I took it off the homepage. It links to the a review for Trumpeter’s 1/32 scale Lightning.
Geez, I already knew that. But that’s not what I’m asking.
I just want to know why the cursor doesn’t change while passing over the smiley or other images in my sig, while it does change, say, for the smilies in that conspiracy thread…
Fade to Black…
[:I]
Oh, I didn’t realize those were links. I see what you’re talking about now. I find that interestingly odd and to be honest, I don’t have an answer at the moment.
Okay, no prob! Was just curious.
However, I do expect a solution by noon-ish (your time) on Monday… [;)][:p]
Fade to Black…
