Does anyone know if the Blackbox cockpit for the Tamiya F-4J (1/32nd) will fit in the Tam. F-4 phantom II.
As far as I know the Tammy J is the only J in 32nd (I have just built one - nnnnnnice!)
The Blackbox F-4J cockpit is for the J model only. It can’t be used in the “D” or “E” models as their cockpits were different than the Navy Phantoms. If you have any other version of the Phantom, you will have to use the stock cockpits or buy the Blackbox cockpits for that version. Even the AF “C”, “D” & “E” each have different cockpits.
i have some spre bits fo the tammy c/d if you need them
