question asked a hundred times,, why not once more
no i know there is like a thousand forums on how to make hay for 1/72nd scale dioramas and i know the cheapest if not the best way to do it is with paint brush bristles but i cannot remember how to make them stand up on there own is it the “plaster of paris” stuff that i should be using???
Duckman, by “hay,” do you mean bundled up dry grass used to feed livestock, or do you mean living grass growing in a field? Since you mentioned making them “stand up,” I assume you mean the latter.
The simplest way I’ve found is to drill little holes in your groundwork, and plant your grass bunches at a time.
I suppose with wet plaster groundwork you could just stick 'em in, but you might not have much time to work with before it dries.
Hope this was some help![:)]
thanks i geuss i should start drillin
