I’ve started a few threads but some of them I cannot reply to a response. At the bottom of the post there is usually a box for text and a “reply” button. Sometimes there is no box, but there is still a “reply” button that does nothing. Can anyone explain the issue I’m having?
Well, it could be:
- you are not logged in to FSM (unlikely but?)
- you haven’t typed in any thing to “reply with”- that confuses the computer something fierce.
- you have been chosen to be a beta tester for an alien technology ( like number 1, unlikely)
Good Luck hope you get it figured out
In this case there is a white box for me to type a response. And there is a blue “reply” button when I’m done and ready to post. Sometimes there is no “white box”. #1, I’m always logged in. #2 no white box, no way to type before hitting “reply” box. #3 never met an alien to date, still waiting so I can introduce them to Mexican food and save the human race.
My [2cnts]. When there is no box, I usually hit reply and a box shows up. Then I type in the reply and hit Post. It usually works for me. Hope that this works for you.
Jim [cptn]
fox has the truth of it- at least mine works the same way .
Re: your #1 Good, you’ll never miss anything of modeling importance
#2 foxs answer, also look at the last message in the post , reply box should be there
#3 Perfect, now I can sleep well at night knowing you’re on alert
The reply box only appears under the last post of each page. Its basically the same as other forums who have a quick reply option. Unless you need to reply to a certain post with quotes, you just use the box at the bottom.
