Question about painted panel lines
What can be done if the paint was sprayed on too heavy and covered up a lot of the panel lines? I don’t want to re-paint every piece. I’m thinking about scribing with a thin blade to remove some of the paint before I do an enamel wash.
Eric, I believe that Paul Budzik uses that technique as well. You can find a tutorial about it at his website:
http://paulbudzik.com/
Good luck, Gary
I also rescribe lines if I have to. It takes a super sharp knife- I now use a scalpel for this. And, a good, flexible small straightedge.
A sewing needle chucked-up in a pin vise is what I use. It may leave ridges or “burrs” along the edges of each line, but a light buff-over with #0000 steel wool smooths everything out.
If the kit has DEEP engraved panel lines, sometimes it’s a good thing that they get somewhat filled-in with paint.
