I just picked up the AMT kit 38388 with the B,C & E Enterprises… what scale are they & best colors to use on them? Any input will be appreciated. Thanks, Eddie
I’m thinking they are in 1/2500 like the 1701, A and D set. The Polar Light’s 1/350 A calls for white, off white, and light grey for the aztecing. The B probably is the same as they are similar shades. For the C you could probably go with the same colors as the D and maybe the E as well.
I have the Polar Lights 1701 which appears to be 1/1000 & the 1/350 NX-01 now this 3-pc set. The color lists are different is why I’m asking. Is there a “standard” paint scheme for the ships or, are they suppose to be different?
I’m thinking with the C and E it would be a bluish gray color overall with a few different color accents and Buff colored escape pod hatches and the B would be a lightish gray but with the B I would try mixing white and silver for that desired color.
Thanks Mikeym, I’ll give that a try. I just don’t want to spend an arm & a leg on paints for just a couple models. I’m on a very limited budget[
][banghead]
