PZL-37B Łoś (Moose)
Finished not long ego after a long battle with the MIRAGE kit [:P] 1/48 PE etc…
Some photos from bench:
Looks great, I don’t know about the Moose very much though.
Hi Andrew,
All is covered in Wikipedia about this airplane…More than I can say :slight_smile:
http://en.wikipedia.org/wiki/PZL.37_Łoś
Very nice, I have seen this in the flesh 2or 3 times now and still find some details .i thought it looked familiar…
Very nice Build of a not so nice kit. Thanks for sharing.
Regards, Rick
Hello,
Van, I’m always glad to see a bit of modelling connected to Poland in some way. The model looks good, too.
The Łoś (pronounced almost like “wash”) is a very special aircraft for most polish modellers older than 25 years - for many people it was the first kit they built, the reason being you practically couldn’t get plastic model kits other than those polish made aircraft before 1989 in Poland.
And the Łoś is also connected to Canada - many engineers working on this machine went to Canada after WWII was over and worked, for example, on the Avro CF-105 Arrow.
Thanks for sharing, have a nice day
Pawel
Simply marvelous, Van! I have this kit, and the Part exterior PE- and very little information about the aircraft. What other accessories did you use? Your build is a real inspiration, to say the least! The slats look like a real pain, but are fantastic- worth the effort.
Cheers!
chuk
Chuckw, does that mean you gonna “do” the Łoś with like two polish cartoon girls building it and a “złoty” to supervise[:D] Just can’t wait, have a nice day
Pawel
Van,
very nice build indeed.
For those who plan to build one (this aircraft is also waiting on my workbench [:)] ) I just got a nice reference book, more than 500 pages including English translation of some crucial facts. A lot of pictures. A book written by a team of historians among them Mr Andrzej Glass (PhD), T.J. Kopanski J.B.Cynk …
I am going to build one as soon as I read all of it :slight_smile:
Chuk,
It took me a year to finish this model with short brakes for couple other models…
The problem with this model is : some part don’t fit and there is a lot of sending etc…
Here for egz the two half of fuselage have different opening shape for the rear gunner. I used piece of frame from PE to make the two sides the same…
After
Here I cut out this part and worked out stead of using resin parts ALSO i cut this in half worked around: TAIL also has been modified: Adding details around engine: The landing gear where wrong on the kit. i maked my own sort of…base on photos: OIL RADIATORS PE parts… I make a jig to put all the small ribs inside and glue them all at the same time… THE SLATS are cut out and the gaps are filled with miliput…than sanded, sanded, and more sanded…to shape… The large bomb bay has been opened for the 2 300 kg bombs Inside the bay i used corrugated aluminum. That’s what they use originally inside the plane. For the bay door i used tank fenders, bend and cut the fenders to the size and shape… Playing with PE parts: In painting i had done everything: pre shading, post shading…painting…a lot of experimentation with paint…Agama, Vallejo, Master M…etc. In general this model was a big step ahead in modeling for me… Still want to do PZL 11, PZL 24(Greek), PZl 23 “So many models so little time” :slight_smile:
Dzieki Pawel,
First model I build was a LWS CZAPLA from “RUCH” in…'70s :slight_smile: I have one in my drawer…with complete PE set for it :slight_smile:
Van,
You did a great job documenting your work.
I like the jig for a radiator.[:)] I did not catch: what PE set did you use ?? I will keep these for a reference while building my kit (hopefully soon :slight_smile: )
Thanks for sharing
There is a 3 sets of PE available from Part. You can have a look here you will find them on this page: interior, exterior and flaps…1/48 scale
http://www.jadarhobby.pl/advanced_search_result.php?search_in_description=0&keywords=pzl+los&pfrom=&pto=&button.x=0&button.y=0
Thanks again, Van- the WIP pics are priceless.
Cheers!
chuk
Nice job. It kind of resembles the B-25 a little bit.
Some more photos from WIP…If someone want to make the Oil Coolers from PE parts will also need to do a small modification under both wings. The coolers are flat and they should sits under wing flat …as on the original photo(last one). Here are 4 photos step by step to make the coolers sits flat…
On right original Mirages …Oil Cooler [bnghead] …on left already sanded out but the wing still around…
The wing edge is around and the cooler edges are up in air…
Wing edges are sanded down straight flat and now coolers can be placed flat…similar to the original photo
simply great work and non usual subject [Y][Y][Y]
Van,
Very nice build and I appreciate the WIP photos too. I tried this kit a few years back when Squadron first got them. Did not have any luck with it and found it quite frustrating. Needless to say it never got finished and I don’t remember what I did with it. It is nice to see one complete, great job.
-Stephen[cwby]
Great model You´v build. [Y] Congratulations
