Hi,
Just wanted to share where I am with this 7 year old weekend project.
Bolts for the gear housing, I am glad they gave me 2 spare ones …
Next up is getting the tracks finnsished ad load the PB.
Best Regards
Johan
Hi,
Best Regards
Johan
“7 year old weekend project” !! You’ve got me rolling Johan!! [:D][:D]
Still, its coming along…but do you really have to add the bolts to the gear housing??
Now thats a long weekend. Looks nicethough. Is this a Tamiya kit.
Seven year sounds like one of my projects… [*-)]
Nice work so far!
Hello Bufflehead,
Glad to bring a smile on your face ![]()
Yes they do give you the bolts separate, actually I thing they are greas fillers.
Its been on the shelf since I could not make up my mind about getting an aftermarket barrell for it. Today I cant understand why that held me back from getting on with the build…I guess you live and learn ![]()
Hi Bish,
You can find my attempt at the Tamiya Pz II undder this link:
http://cs.finescale.com/fsm/modeling_subjects/f/3/t/106628.aspx
This is the Tasca 1/24. Size comparsion here below:
Meanwhile I have lost so many parts that I will need to do a bit of scratching to get on with the build, among others I have lost all of one side off the periscopes.
Just hoping that it is the outer side that I still have ![]()
Will do some paintwork before I assembe the cupola so that is WIP right now.
Hi Gamera,
Thanks for your kind comment!
Very Best Regards
Johan
Hi,
Summer holidays are almost over and I am back from 10 days in Portugal.
Moving ahead with the assembly of the commanders cupola when I realize that I have lost the outer side of the persicopes.
Unfortunately the inner part is a 1.5 mm to hight to make a replacement.
It might not be visible in the picture but the periscope is protruding over the brackets that are supporting the ring later:
I will not let this stop me at this time, but the parts do look tricky to scratch.
Clear part, triangle shape with one square corner and sides 1,5*1,5 as in the picture above - any ideas anyone?
I am also writing to info@asukamodel.com to see if they can help out with replacement parts.
Best Regards
Johan
I didn’t know Tasca done kits in this scale, its a fair old size. Thanks for the info.
Sorry i can’t help with the clear parts, hopefully somone will have an idea.
