PzBeobWG ausf G dragon 1/72 fake tank wip
Another little armor for my little tank collection [:S]
As i see after an observation tank for artillery support and sight.
It’s my first dragon kit of ever with new features for me, as the metal hull [:|] …why a metal hull? Also included a metal rope, and this is relly good!
Unfortunately for me, the kit comes with vinyl tracks [:(]
Instructions seems not so accurated ,in some case wrong pieces names and some missing step!
So… here the sprues:
Already started the sub assemblies
the turret with fake gun
upper and lower hull is fixed with two screws… actually one … i break one [:$] will glue after with CA glue and putty
At the next
Sounds like the usual Dragon treatment in terms of the instructions! [:D] The metal hulls were added to give the finished kit some weight…but IMHO are just a complication in terms of having to work with the upper and lower hulls. Look forward to seeing what you do with it.
I’ve seen a few of your planes Bsyamato so I’ll definitely be following this one with interest .
FYI, the metal hull may deteriorate over time. I built the Panther G with metal hull (the same hull as your kit) when it was first released in the early 2000s along with the Sturmtiger with metal upper hull. Both have sat virtually untouched in a glass display cabinet since completion.
The front Panther hull, where the upper and lower hull meet, has started to split and the metal is actually crumbling away, creating a gap at the seam.
The Sturmtiger, sitting inches away from the Panther, looks as good as the day it was built.
so bad things about the metal hull … [:(] will try to done another protective layer before to close it. Thinking that best way is to totally remove screws and close the screws housing with some putty to clompletely isolate the nude metal.
Last night also started the academy fuel set!! i brought the set for the working fw-200 condor diorama, soon will put some thread about [:D]
here with the latest supply
as i realized after was a totally german low cost furniture [proplr] (got the Beob at 8€)
Some photos of someone else who had similar problems.
OMG!! i hope mine don’t turn so in future [:|]
some little update:
throw away screws and glued with CA glue the hull. filled the holes with enamel paint. After will seal with molliput the screws housing
and painted wheels ,turret and side skirts with MM sand
I will leave at least 3 days before second coat , i had problems in the past with model master enamels [:(]
Wow I can’t say I’ve ever seen die cast metal do that before. I hope the same doesn’t happen to my Tamiya 1/48 scale tanks.
No, we had some discussions about the Tamiya hulls vs the Dragon hulls. Tamiya Tiger I I built 10 years ago is doing fine. Cheaper Chinese manufacturing standards than Japanese ones.
The split in the bottom picture is what has happened to the front of my hull; the two metal pieces warping, separating and crumbling away. I don’t have it as bad as the top photo, but I haven’t tried to rectify it like he probably did.
Wow .that’s too bad about those hulls. Something to keep in mind.
