my badger 150 is pulsating when i pull back for paint its not the air cos it works fine on my other air brushes it is blowing back into the cup aswell, can anyone help
South Africa
South Africa
The primary cause of blow back or pulsating is one or both of the seals are not seated properly. If the teflon seal on the head assembly is missing or the head is not tight enough you will get pulsating. It could also be caused by the internal teflon seal being worn.
If you can’t figure it out send the airbrush back to badger and have them fix it.
[#ditto] Yep, that’s the problem. Get a new teflon o-ring, or two and replace them every so often.
Andy
Good day
Thank you i replaced it and it works
Thank you
mike
