Propellers Propellers propellers
Is there a source for after market propellers.
i have a stash of 1/72 1/48 1/32 World War 2 a/c kits from various manufacturers.
Well I turned my 10 year old son loose and he has been building them. He pretty much assembles them and when i have time we try to paint and decal them.
I started him out on a bunch of SMER kits and then old Monogram 1/48 kits. I see noticeable improvement. Today’s modelers have SO much wonderful help aides, quality glues, paints etc.Research is abundant. I remember building Lindberg JU-88’s and HE-111’s and using the old Profile series as reference and trying to match up camo patterns.
Humbrol paints have consistently been around and very good BUT with very high quality acryllic paints available young ones can paint and not kill their lungs or smell up the house with fumes from petroleum based products not to mention the danger of “Burning Down The House”!!
Anyway I wish metal propellers were an option as I can’t tell you how many times propeller blades get broken!! Mostly in the 1/72nd scale range and even 1/48.
Right now he is building up all the Supermodel 1/72nd and Italeri 1/72 Italian a/c kits(World War 2) I had stashed and many of the 1/72nd ones have become “Propeller casualties” the blades are near impossible to glue back on.
Any ideas out There???
No and I feel your pain. I recently moved, and however carefully I packed my builds…[:'(]
I think the problem is that aftermarket would be resin, and that won’t do at all.
There was a company, Aeroclub, Aeroscale, or something starting with the word Aero, that did 1/72 white metal propellors. But those can break as well if bent too much. I do not know if they are still in business, but I remember a rack of that stuff at some of the LHS in years gone by…
Broken props are not too hard to repair. Use a pin vise/small bit to drill matching holes in the blade base and hub center that will line up, and put a length of brass rod in there. You can superglue it back in place and it will be stronger than before due to the rod re inforcement.
There are lots of resin replacement propellors out there in 1/48, but they are pricey and more fragile than the originals.
I have a pin vise and some small drill bits I’ll give it a try this weekend.
I was going through my stash of some of the old Lindberg kits hoping to find a propeller I could make use of but no luck.
I’ll report back if successful
Success!!!
I have a small drill bit and used the old sprue trick of warming up a piece of sprue, and stretching it !! I made a thin piece cut it and inserted it into the hub of where the propeller broke. I decided to let some of the piece of the now attached sprue attach to the back side(plane side) of the propeller shaft. I used a small drop of “orange” top Tamiya glue.
Once it dried I painted it and it is hardly noticeable!!! Not to mention I think it’s a stronger attachment.
Thanks to those who gave me a few ideas!!
