Problems with RAF Ocean Gray
Hi again[:D]
Last weekend I sprayed RAF Ocean Gray over my 1/48 Spitfire but it turns WAY TOO DARK it doesn’t even look close to the reference photos I have……[:(]I am not really angry but disappointed for my foolishness of ignore the scale effect but I think this is the only way I can really learn (the hard way).[banghead]
Anyway this week I have run some experiments to find the right colour and found that 50% RAF Ocean Gray and 50% White make a close match but it still doesn´t convince me.
So my question is how can I achieve the right colour?
I am working with Model Master N°2057 enamel RAF Ocean Gray. I also have MM RLM 65 hellblau, Testors light sky blue and MM light ghost gray,
Any help would be greatly appreciated.
Thanks…
How sure are you that your reference photos are accurate ? Lots of things can change in photos based on the quality of the original & the reproduction. If they are color photos from WW2 time frame, be real careful because a lot of those 60 year old color pics have faded over the years. I have found ModelMaster enamels to be reasonably close to the FS paint references. For scale effect, you shouldn’t have to add more than about 10% white. Your 50/50 mix sounds way to light.
Regards, Rick
yeah 10% is the norm. You might also get a good effect by spraying the color as is and then weathering it with stains and making streaks on using the original color with 10% white. The stains would be best in my opinion as Tamiya smoke.
