Does it vary by model type or contemplated finish colours?
I’m asking because I’m building a Dodge Viper and I primed it black. I’m finding that I’m having trouble seeing where I’ve painted black over the primer.
I use black on armored stuff…almost like a preshade, but when I am doing A/C I usually use white since most final coats I use are light in color. For a black finish I suppose I would use a gray.
It just came to me…if you have primed it in black and your finished color is black, why not just buff it a little and shoot a clear gloss on your primer?
Depends. Darker topcoats get black or gray. Lighter topcoats get wihite or gray. Sometimes I use silver if I want to show paint chipping. I have obtained real good results using decanted Krylon primers. I also read somewhere that Floquil Engine Black makes a great primer.
If your Viper’s topcoat is black, I would have used gray primer polished smooth to get rid of any small bumps and then shot the black over that followed by a clear gloss coat to give it a wet look.
So my next question is: can you use an acrylic paint, applied with an airbrush as a primer. I’ve heard of “misting” the paint on lightly for better adhesion so I was wondering about building up with multiple acrylic “mists.”
I’m just wondering about a priming method other than rattle-cans outside in sub-freezing temperatures.
