Pre-shading your office
In another thread I mentioned pre-shading the interior of a P-40B I’m working on. Couple of people asked me “What’s that?” so I figured I’d share.
I got the idea from an article in the April 2006 Airplane International. The writer was showing how he finished resin pits. I read his methods, and then sorta adopted what he did to my not-so-patient-still-building-skills techniques. Plus, it was a great chance to use my new airbrush.
First, I built the major interior components- unpainted. Sidewall panels glued on, seat to floor, stick, etc. I let it dry, and then airbrushed the whole affair flat black. (In the article, the author used a mixture of French Artillery Green and Matt Black… so I’m lazy. [:)])
After that dried, I thinned down some zinc chromate, and began lightly misting over the interior pieces. For the sidewalls, I did it a little above perpendicular from the side, and for the floor, straight on. I slowly built up the color until it was mostly ZC showing, not black. Along the interior rib lines, etc, the black still shone through. (I actually should’ve stopped about 2 passes earlier than I did- I had it just right, thought I could get it “righter”… live and learn.)
Once that dried, I broke out the ZC again, and my short bristled brush for dry brushing. I then dry brushed the raised detail only. After that, I lightened up the ZC a bit, and did another pass at dry brushing.
The photos below show it at this stage. (The contrast doesn’t show as well in the photos as in person. Trust me- even in this first attempt- I see a lot of potential.)
The next step will be dry brushing and washing as normal. The article goes into great detail about it.
What I learned:
  • I need to be more precise in applying the “mist” layer. I realized I should’ve followed the article a bit closer and really tried to hit just the flat high surfaces a bit more precisley.
  • The technique, to my eye, really makes the interior details “pop out”, really providing good contrast.
  • It’s gonna take some practice- but I like the results.
    If this is a common technique- forgive me taking up space with common knowledge. I thought it was cool though, and I’d like to hear from anyone who trys it. Plus, it’s just fun to try new techniques.
Just noticed as I looked at the pics I posted: How did I miss those ejector pin marks?!?!
Sounds interesting. Worth playing around with. Thanks for posting Jon
That does sound interesting! I’ll give that a try with a P-47D that I’m about to paint the interior on. I have a bottle of Tamiya Black Green, I wonder if I could cheat with that?
I bet that would work well… based on my grand total experience of one try [:)], it seems that as long as the first coat is dark enough to contrast with the lighter shades to be built up on top, it should shine through well.
If you get a chance to look at that article- trust me, it’s impressive looking. Is it maybe a bit overkill? Could be. Is it a chance to play with my A/B and see how nice I can get stuff looking even though no one will see it when closed up in the fuselage? You bet!!! Wooooo!!! [8D]
