i was looking in the special issue of finescale moderler and i was looking of the pictures of the d-day armor,i wanted to know what is more better making the,dusty,dirty look on it .i was thinking.1.do i put my powder on the brush then brush it on the model.2drybrushing,do i bry brush the model by making it look dirty or dusty.3.or airbrush but not brushing the hole model,just a very fast motion.tell me,if all these are wrong tell me,and tell me the real one,best
one ,i was looking on p.61on american forces at the m4 sherman.for an example thanks
Some do a combination of all 3 techniques you have mentioned
I use the first method you mention the most for giving my models a dusty look.
Drybrushing I use to highlight areas to give the impression of depth.
The third method you mention is to spray a light coat of paint in an earth toned colour to achieve a dusty look. Most common colour I’ve seen used is Tamiya’s Buff thinned down a little bit.
Personally I haven’t tried this method becuase I’ve been happy with the results of the pastels.
Oh yeah, use all three methods. You might airbrush an earth/dust color on the lower parts of the tank, dry brush on areas of wear, use pastel dust all over. Only the lead vehicle in the convoy don’t get covered in dust. This is a fun part of the process.
G.L.
Drybrushing is done to enhance the raised areas of a model, and should be as common a weathering technique as any, as it should be.
Usually, I’ll airbrush a dustcoat overall to tie everything in on a model, then dust with pastels any areas that I think need more. Also, pastels are great for roadwheels, wheels, tracks, etc, as you can push the dust into the ‘corners’ of wheels, between tire treads, then dust off the excess that’s above that, resulting in a very convincing look.
On my Panther, for the first time I tried airbrushing a mist coat of dust and mud. I am pretty pleased with the results. I used Floquil’s dust, dirt, and mud weathering paints. it really wound up looking very dusty.
