I had no problem until the forum update.
How do I do I do it now?
Thanks
Mark
Thanks
Mark
Hit the Settings button on the right side. that should take you straight to your sig edit option.
Thanks.
I’ve tried that. I keep getting a “Validation Error”
Ok, not sure then, maybe a problem with the link. I just altered mine and it worked.
I figured it out and I feel silly.
I tried uploading it from my desktop instead of using an image hosting service.
How do change the size of the badge before you add to sig?
You have to adjust it in the same way you would do normal photo’s. This can either be your own pic editor or Photobucket if you use that.
I keep trying thank you
Are you have problems loading the image due to the number of charectors
No I would like the gb badge smaller and I got it thanks
