Post-Shading with Tamiya "Smoke"
Have any of you guys used Tamiya Smoke to post shade? This is a clear type gloss paint. I recently saw one of Italeri’s 1/35th MTB’s post shaded with this (the modeler didn’t elaborate on his method) and it looked pretty great and added a lot of realism.
What thinning ratio should be used to get a subtle effect without going overboard? No pun intented.
I would guess with this technique that less is more.
Comments appreciated?
Very thin paint. Put the thinner in ur paint cup first, then add just a drop of Tamiya smoke. Practice on a post it note first. You want it so it’s almost invisible until the third or fourth pass. Get in close and lower the psi to 8-12.
Thanks, Nathan
Nathan is spot on. I use Tamiya smoke for lots of things. Great product.
I use it all the time. This is an example on my P-47.
I used Gunze Smoke for post shading on a few builds back in the 90s. I was very happy with the results, but cant really say what thinning ratios that I used or other such details, being so long ago.
All I can suggest is practice on an old build (save an old beast for just such purposes- I had a test bird) before you try it on a new high value project. Seeing how I recall doing the post shading over decals, you dont want to bone up at that point and have to regroup from that point…
what is Tamiya smoke? what is part number?
X-19.
