"The F-106 could only be flown in the USA or Canada and could not be deployed overseas. " – Berny13
I have to disagree with you there, Bernie, because during the Pueblo incident in 1968 or '69, the F-106s were sent to South Korea to stand alert. There is a hilarious photo of a Six Pack, which had been spiffed up for an inspection by a Lt. General, fitted with a triple ejector rack under each wing on the fuel tank hardpoints. And from each station of the TER hung a 500-lb. bomb, six in all. For those who might not know, the F-106 was a pure interceptor, and not designed to carry bombs, and was not capable of bombing, but the gesture was meant to tell the General that this squadron was prepared to do anything for king and country, or rather, Uncle Sam.
But also, Bernie, thank’s for illuminating this stuff as one with firsthand knowledge, which I don’t have nearly as much of as you – mine’s all from sources on the Century Series and friends who flew them, except the one CF-104D which I knew intimately and got to fly in several times. And I don’t mind at all being brought to account when I’m outright wrong, as I was, and I went back and fixed some of the things Bernie pointed out. I have to apologize to you and all the others for not serving history or journalism well by calling the F-102 a disappointment. I was just parroting that same old “conventional wisdom” about the Deuce without doing my homework, and fact checking that blanket statement of mine would have been easy, since I have two close friends who flew them (with our pres, GWB) in the 111th FIS, TANG. From memory, I recall my friends saying the Deuce was underpowered (what jet, except the F-104, from that generation wasn’t underpowered?) but otherwise they remembered it fondly, moreso than the F-101. Without that “disappointing” Deuce, we would not have had the B-58, the F-106, possibly the XB-70, which, though cancelled, provided invaluable high performance research data that is used to this day, and, the greatest contribution of all, the area rule, which allowed subsonic aircraft, just by pinching the fuselage at the waist, to suddenly become supersonic aircraft.
And since this thread has become one about Century Series jets in general, here’s another couple of F-101 Voodoo stories that, I think, I’ve told on this site, but maybe they bear repeating – or, maybe not. But here they are anyway:
When the Canadians flew the F-101B as their front-line interceptor, they used to do exchange programs between themselves and U.S. F-101B units, which by then were all Air Guard squadrons. Two of my friends spent time in Canada with the RCAF squadrons, and even to this day the Canadian pilots are not only known for their great skill, but for their, um…love of fun, yeah, that’s it…as well as their sense of humor, dark though it may be (They were the ones who named the F-104 “The Aluminum Death Tube.”)
But they exposed my friends Bob and Dan, both 101 pilots, to a trick they liked to play on the civilians on the ground at night. The F-101B model had a blinding searchlight built into the left side just underneath the canopy area. It was for identifying aircraft at night, and apparently wasn’t a very good idea, because I’ve never seen it on any other interceptor in modern times. But this light was as bright as the sun. So the Canadians would take two jets at high enough altitude that their engines could not be heard down below, then light the afterburners of one as well as the searchlight. The two airplanes, one dark, the other lit, would approach each other head on at just under Mach one. At the exact instant they met, the lit-up plane would turn off the light and go out of burner, while simultaneously the dark plane would turn on both his searchlight and the afterburner. It gave the effect on the ground of a very fast UFO making an instantaneous reversal of his course, an impossibility given our primitive Earthling technology. It used to drive NORAD crazy because of the phone calls, and when the secret got out, the Canadians got a good reaming out. But wouldn’t you have loved to have witnessed one of those “UFO” sightings?
AND:
As most of you know, the early ejection seats were not only user unfriendly, they were downright dangerous, and many pilots died because they preferred trying to ride a stricken plane down than risk an almost certain career-ending back injury from an ejection (and that was one of the less gruesome ejection-related injuries that occured quite often in those days).
My friend Dan, who had just transitioned from the F-102 to the F-101B in the Guard, had strapped in and was in the process of bringing the engines up with the aid of the huffer. The 101 had a bad penchant for catching fire, as well as for blowing up in midair (it was a problem connected with fuel pooling under the engines in the fuselage, and was later corrected by the addition of two simple holes in the lower rear fuselage, I believe).
But to the point, Dan suddenly got a fire warning light and the crew chief frantically signaled to Dan and his WSO to get out. Ground egress with these old seats was a multi-step process, and you could burn up before you got everything unstrapped and unhooked. Well, Dan pulled the lever that severed the necessary things that attached him to the seat. He unbuckled and deftly leaped overboard, a pretty good jump from that big jet, but given the alternative…
Anyway, Dan, who is short and wirey, had forgotten to unhook one thing: the hose to his oxygen mask, which on that aircraft plugged into the left console. So as soon as Dan was over the side, he found himself dangling helplessly by the oxygen hose, which might have broken his neck had it been less flexible. The alert crew chief ran up, reached to the snaps on Dan’s chin strap, and flicked it off, causing Dan’s helmet to come off and he collapsed in a heap on the tarmac. The aircraft was a writeoff, and thank the lord it was unarmed, because Dan would have been written off, too.
Tom
