Pledge Floor care Multi - Surface (PFM) use .
In the new monthly Fine Scale modeler (PFM) was used through out the construction / air brushing of the F-84 . I am wondering if anyone would have any ideas on the proper mix to air brush this correctly. I would think this would be very thick to actually be able to use. Any thoughts?
If this link is what you’re referring to, Pledge Floor care Multi - Surface is a new name for the old Future.
www.amazon.com/…/B0034792NM
It is thin enough to be used direct from the bottle for airbrushing, no thinning needed.
I aibrush it right from the bottle,clean brush with windex.It has good leveling properties.
I airbrush it right from the bottle. No issue whatsoever.
It airbrushes right out of the bottle,and it is in fact thin enough to act a a combination thinner and adhesion enhancer for some brands of Acrylic paints.
I too airbrush it directly from the bottle, haven’t had any problems.
