Can someone pint me to a site that sells the plastic sheets that looks like water? Thanks
Try your local hardware or building supply store. There are a few of those sheets that go in the light fixtures for suspended ceilings that work as water.
COOL…never thought about that…been looking and found Plastruct (http://www.plastruct.com) that had this, but it is only 14 by 24…a little short for the Titanic. Thanks for your input. Mike
Hey. Went by Lowes and loked at one of those textured light covers. Looks good and I think it will work. Only about 10.00 and plenty big for the Titanic. Great suggestion…many thanks. Mike
I am also in need for the water like plastic for my model train layout so thanks for the tip.
I’ve found that it’s best to score the smooth side for cutting. This, whether using score and snap, or using a saw of some sort.
For the former, I find a heavy utility knife a better choice than an xacto or scalper-like cutter.
For the latter, using a fine veneer blade installed “backwards” in a variable-speed saw a good choice. This puts the teeth of the blade into the “sea” surface, so any splintering is on the back (easier to file & sand clean) side.
Truth be told, my tool of choice for the light lens sheets is a Rotozip with a laminate-cutting bit. This, however can be kind of spendy for some one who is not going to install a lot of plastic laminate counter tops–legacy of a life time in construction for me.
