Plastic model ruined-Please help
Heres what happened, I primed a plastic model car with a can a testors white primer with the intent of painting it with a lacquer paint. I was later told to strip the white primer and use automotive light grey primer instead because the testors white primer and the lacquer paint would react badly together. So heres what I did, I stripped the off white primer and then dipped the entire model in a bath of lacquer thinner thinking this would help prep the model for the lacquer paint, the model now appears to be ruined as Its covered with shiny blotches thru out. I think what happened was I still had a good amount white primer on the inside of the model and it mixed with the lacquer thinner and caused a bad reaction. I tried to sand the model to get the blothes off of it and it didn’t work. I was thinking of dipping it in Castro Superclean to see if that would clean up the model again so that I can prime it with the Automotive light grey. Please advise as I’m very disappointed since this is a vintage 67 mustang that I’m trying to refurbish. Thanks…
OUCH!
To put it short, laquer thinner melts plastic!
The only way to play it safe is to use white spirit or equivalent or some kind of alcohol when cleaning models because these wont eat the plastic as the thinner will.
I think you can forget this model and move on to the next one, that’s the down side of it. On the up side you got some fresh stuff for the parts box to use on some other project.
Niclas
Sounds as if Niclas is right - this one is probably for the bin. If the thinner hasn’t warped the plastic you may save it with a coat of sanding primer but you’re almost certainly going to lose some detail. Flatten off the sanding primer and then go with the gray as you first intended. May work - fingers crossed! Martin
If nothing else , it is not a complete loss. You now have a body to practice painting techniques on.
hey can u post some pics to show us the damage?
I learned a long time ago that when you paint plastic with lacquers you need some protection. Floquil used to make what they called “Barrier”. It was a crystal clear protectorant that you sprayed on your model. You could then use lacquer based paints and not worry about them attacking the plastic, no matter how lightly.
Floquil doesn’t make this product anymore, but Scalecoat has a sealer that does the same thing. Take a tip from an old timer, use this stuff and then when you mess up you can strip the paint and start over again.
I think your Mustang is a loss ,not knowing the extent of the damage. From passed experiences with lacquers, I’ve found that a coat of Krylon Primer or two makes a good protection barrier between plastic and lacquer paint and most paints. As for stripping off paint old or new paints I’ve used Easy Off oven cleaner (Blue can) remember to protect yourself it burns on skin and eyes. For the body, if damaged beyond repair try looking up a club site, they may have a scrap yard and maybe a member has a spare in their box. Good Luck and Let’s Hear from you.
Ken,
I would be very leary of that Krylon paint too. I’ve seen Krylon attack plastic too. Use Scalecoat’s sealer for lacquer paint to be safe.
Hello Big Jim, Thanks I’ll give it a try.
I’m now building AFV’s, but for years before my switch I built cars. I used lacquer paints exclusively. For primer I used Plasti-kote Sandable Primer, T-235 Gray, which comes in a spray can. It’s a fast drying lacquer based primer. Works well on plastic. Can find it in many auto parts stores.
And yes…unprotected styrene plastic and lacquer thinner do not mix. Bet you won’t make that mistake again. I ruined a car body that my then 9 year old son was working on. Did he have a long face, until I bought him another kit like the one I ruined.
HTH
Glenn
P.S.- I prime all my current AFV parts with this Plasti-kote primer as well!
