I have seen mentioned that there are decal sheets that are plain, nothing printed on them, just the film. When ordering these what is the description or proper name. I am scratching my head because I have to create some. Also for decal creation I was planning on using a scanner and photoshop then printing them with my inkjet, will that work or is there some special technique to creation?
Crap…answer was down below…need to pay closer attention…sorry
I just went through this procedure to make some decals.
First off trying to print with an ink jet is a pain … much pain. If you don’t have access to a lazer, go to a local printing company and have them do it for you. It will save you a lot of grief.
Building your graphic on the computer works great. Save them in the size that you want and bring the disk to that printer I was talking about.
Finally the paper … I had the choice between using a clear decal paper or one that has a white background. I chose clear and shouldhave went with white. There is lots of colour leeding through a light tone if you are puttingon a dark background so go with the white if you can, it may make it a little easier.
mucho gracias shermanfreak…the info about ye old laser vice inkjet has probably just saved me a load of consternation and years shaved off my life
My pleasure … just saving you some of the grief that I went through already.
