Hello;
Any ever put these on a ship model before and what would be a technique for doing it.
Bill
Hello;
Bill
Yes, I have. The best technique I’ve found to install these tiny little things (in 1/350 scale ) is put a little medium thick CA glue on a post it note and use a tacky pick-up tool to dip the port hole into the glue and install it on the model. It ain’t easy to get the thing aligned with the drilled port hole in the model but once the CA is set,the pick-up tool comes right off.
I make my own tacky pick-up tool by diping a tooth pick into a waxy substance called Drumstck Wax made by Zildjian . You can find it at any music store or at www.zildjian.com… way cheaper than buyng the pre made pick up tools at your LHS. Actually, as a musician, I already had the Drumstick wax on hand.
Another glue to try is a product I just got called Gator Grip Acrylic Hobby glue. I got it by mail from the mfg. by Google ing it on the inter web.
By the way, these potholes make realistic guages and dials for scratch building aircraft cockpits too.
In 1:98 and 1:192 I insert aluminum tubes, with polished ends. To me 1:350 is too small and I don’t worry about porthole frames. If a warhip with portholes open I drill them out and use microglaze for glazing.
