I have put some pic’s on photobucket, how do i get them on to this forum?.
Easiest way is to use copy and paste. Check the boxes for the ones you want on photobucket then go to the bottom and click Generate HMTL and IMG code. Then pick IMG for message boards and copy the text. Next paste that in your Reply box on this site. You should be go to go with that. Hope that helps.
Smokinprice
Under each picture on the photobucket site, there is a code for each picture. It usually is the photos name, and a tag like jpg.
To post the picture first click on the insert picture button. This will put little codes like in front of your text. Now, to put a photo in, write the code for the picture in between the two little picture codes. so for example mine would be this, (with spaces added so the photo can’t appear.
Here’s what the photo looks like with the full code in.
I guess my examples show up as errors, so slap me.[V]
When posting images…
Place the URL between the following [ img] and [ /img]. Be sure to take the spaces out, otherwise, the server treats it like an image tag, which is why stukabomb needs to be slapped [;)]
Jeff
On Photobucket, Open your album for the pics you want to post. If you want to post the thumbnails, right click on the pic you want and select properties. hold down the left mouse button and drag the mouse across the url shown in the properties box. When it’s all highlighted (make sure you get all the way from the first character through .jpg), release the mouse button, hold down the control key and press the C key. Then flip over to FSM, click in your reply box where you want the pic to be, type [ img ](without the spaces), hold down the control key and press the V key. Finally, type [ /img ] (again, without the spaces) after the .jpg and your pic should appear when you post the message.
If you want a bigger picture to be posted, do the same as above, but when you find the pic you want to post on Photobucket, click on it first and that will open it as a bigger picture. Then do the right click, properties, etc. bit and copy that url.
Good luck
