I did a search trying to find out recommendations for PE manufacturers. It looked like the posts were a couple years old, so I’m sort of looking for updated opinions.
I am planning to dive into my first PE project(s) which will be the HMS Hood and USS Missouri.
My questions:
Of the two ships I have to build, which one would you start with for your first PE endeavor?
For said ship, which manufacturer would you go with?
Its pretty vague out there, but I seem to get the feeling that for a first timer, GMM edges out the competion ever so slightly. Price is not too much of a consideration for me so I’ll pay a little extra for something that will be tolerant of my burgeoning skills. [:)]
What scale? I only do 350th, but in that scale I can say Gold Medal and White Ensign both make beautiful detail sets for Missouri, I plan to do another one static display only and am leaning towards the GMM sets.
For Hood I would probably pick Lion Roar for first choice, WEM second.
I would recommend neither as a first ship photoetch project. Both are large projects with lots of little fiddley bits. Both are relatively expensive, with the photoetch sets becoming very much so. You may become hesitant to dive into the projects for fear of screwing up the expensive material. The project will seem to go on forever with no end in sight.
What I would recommend is a photoetch learner kit. A smaller project with fewer parts. You will have the satisfaction of seeing the end of the project, and by completing it you will have the knowledge and confidence to undertake a larger, more complex project.
What I would recommend is the Tamiya USS Fletcher or the Trumpeter USS England. Both are 1:350 scale and are relatively inexpensive as is the brass. Being less expensive you will not fret as much when you make mistakes – and you will make mistakes. You will be able to see either of these projects to completion and gain the knowledge and confidence to undertake the larger project.
VV edit
Let me run some numbers past you. The following are MSRP in US Dollars. Your purchase price may vary:
Tam Missouri $105.00 GMM PE $42.00 or WEM PE $83.21
Trump Hood $116.99 GMM PE $42.00 or WEM PE $83.21
Trump England $ 33.00 GMM PE $20.00 or WEM PE $33.24
Tam Fletcher $ 36.00 GMM PE $32.00 or Flagship PE $38.00 *
(* WEM does not make a Fletcher PE set. The Flagship PE set for the Fletcher is equivalent. I do not recommend Toms Modelworks PE to a novice (even thought they are less expensive) because the brass is softer and smashes easier.)
You can see, that at 200 dollars - the Hood can be an expensive learning tool. But for less than 75 you can learn the techniques which you can then apply to either the Hood or Missouri later.
^^ edit
I am also considering adding the Revell Emden German WWI cruiser to my list of learner ship kits. The photoetch is only available from one source (GMM) as opposed to multiple sources for the other kits.
I do not recommend the Trumpeter USS Sullivans destroyer for a novice kit. There are too many issues with the kit which need to be addressed for a novice to undertake.
Ed has some very good points. But he forgot to add that GMM maked a PLUS set for the Mo. I built the Tam Mo with both sets plus I added fPE loated baskets, and PE reels. It was expensive, and it took a fair amount of time, over a year. The SK radar is time consumimg as well and very delicate, and its easy to mess up big time.
We want you to get a good start in this part of the hobby, and I think the USS England is a very good start, and will give you the chance to develop your skills, and finish in a reasonable time.
Did I forget to mention that on the Mo there are 48 40mm guns and each take 5 pe parts alone!!! I also used L’Arsinals quads with photo etch. 16 of them. As you can tell it still has affected me in that I can quote the parts!!
Here is a link to some photos of the finished model
Dick and Ed make a good point about starting with a smaller kit, good advice though if you’re determined to do a battleship go for it. My first project was about three years ago, a fully rc converted Tamiya Misouri with Tom’s Modelworks PE. But then a lot of people might point out that I’m not exactly normal.
If you’re the kind of person who is easily frustrated you should probably start with a smaller project, the Tamiya Fletchers do build into nice little display peices.
I chose not to include the GMM Plus set because it is an set offered for use IN ADDITION to the basic PE set offerings. I felt it would have been confusing. I was trying to compare apples & apples. WEM has a similar additional set. Both get you additional light weapon details and gun tub ready racks.
The GMM Plus set is another USD$42.00 (MSRP) on top of the $42.00 basic set.
The WEM Plus set is another USD$48.20 (MSRP) on top of the $83.21 basic set.
(I really wish the exchange rate was better!)
This continues to demonstrate my point that using either the Missouri or Hood as a learner kit is an expensive proposition when compared to the Fletcher or England.
Novice mistakes will be made. I made them. Others I’ve talked with made them. I still make them, but hopefully not as often and not as serious - and I’ve learned how to recover
GMM offers a ‘Ship Modelers Handbook’ giving tips and methods for placing their products on models. I purchased this publication along with my first GMM PE set (1/350 BB Missouri) and studied it before placing any PE parts. The handbook was a great help to me as a beginner.
Since then I have completed the Bismark, KGV and Mikasa with GMM PE sets and the Arizona and O’Brian Liberty ship with Tom’s Modelworks PE sets.
Things get easier as you go along. The 20mm and 40mm gun builds are tedious but become easier as you learn what works to make the builds quicker and less trouble.
In January I completed two 1/72 type 7c uboats as a single display combining the Yankee Model Works pressure hull kit, four CMK resin inserts and four figure sets, White Ensign torpedo loading PE and resin kit, Nautilus Models wood deck kit, Revell figures set and some scratch built parts.
Working with the PE sets led me to more ambitious projects. I am placing small motors in WWII propeller aircraft to turn the props using an external power source.
Thanks for the input. I think I’m going to get the Fletcher and the PE from GMM. I’m also going to pick up that book from them too. [:)]
The Fletcher will also be my first crack at the camo of the super structure. Up to now, I haven’t tackled that part of either the King George or the Bismarck. I think it looks awesome and I think I’m going to give it a go on this one. [:)]
Thanks again for the wise suggestions…I’m off to do some ordering. [;)]
I’ve been leery of using any PE from Lion’s Roar because there has been talk on this board, and others, of them, ummmmm … producing frets that bear an astounding resemblance to PE frets put out by reputable companies like Gold Medal Models and White Ensign Models.
i have heard the same and i am investigating it myself. until then, i will just stay away from them. as far as i’m concerned, i know WEM and GMM are legit and have all i’m looking for so they will get my business. although i’ve only ordered from GMM so far.
Thanks, that is the Tamiya kit with GMM detail set. On the next one I’m going to try and graft the trumpeter square bridge and the midship Bofors mounts onto the Tamiya kit along with the GMM and Eduard sets to try and do a decent representation of a WWII Cassin Young.
I know this is a family forum, so I won’t say what came to mind [:D]
My only experience with phote etch to this point has been the two Trumpeter kits; Morser Karl and Leopold, both in 1/35. It seemed relatively easy.
As I look at this fret from GMM I now realize why it and the Fletcher were recommended as a first kit. [:O] holy smokes!!! thats some fine detail.
I hope I do this build justice. If I can get it half as nice as ChuckO’s I’ll consider it a success. Pictures will be taken and I’ll post them when I’m done.
Contact me off list. I have a presentation I made at the IPMS Nats a few years ago. It was on resin ship modeling, but I went into brass preparation and assembly. It will give you some hints & tips for working with ship PE
Those frets look pretty cool when they come don’t they? Just take your time and try to picture a couple steps ahead so you don’t add something before you should. I built each section seperately and complete before attaching to the painted hull. The main thing to remember doing it that way is to test the fit again after the sections are painted and before you detail them. That was my big mistake on that model, you notice the center section does night sit tight to the deck, by the time I realized it everything was already covered with fragile little brass peices and I was reluctant to get too heavy handed at that point.
I’m sure yours will come out just as good or better. I’ve only been modelling for a couple years and that one is only my fifth model ever.
