Good idea. That is what I got the insulin syringes for. They have an extremely small needle, which also makes the tiny drops. I want to try the clear enamel method also. I like the idea of having it sticky when I attach it. With the thin CA, its either all or nothing when it bonds, and with the slow drying CA, its so thick it makes a blob.
You’re lucky, at least your PE is on the same planet. I think the first piece of PE I zinged away has just left the solar system. I use carpet tape (sticky on 2 sides)on a pane of glass. Stick the PE fret to it and then once cut, the part is right there and won’t move until you want it. Keep up the PE work. It has turned my ships from “Hey that’s neat” to: “Wow that’s amazing” using nothing but railings.
Keep building
Paul
Well I finished the model (never did find that PE i dropped) and from now on I work with a white bed sheet on the floor under my chair and the model table, at least I have a chance that way.
