PELELIU
Guys, all comments are welcomed. I should have the rest of the diorama finished in a day or two.
Thanks
Mac
I finally finished this project.
Thank you and I hope you like my little project
Mac
What did you do for the .50 cal brasses on the deck by the M2s?
Col Hogan
It’s stretched spruce painted brass and sized
Tom
Mac,
In goeneral, I like the concept. As some other people mentioned, your water needs some work, but it is a heck of an effort - what did you use for the water?
One comment: in the second to last photo (I think) the gunner on the right hand .50-cal (from the perspective of the viewer, not the trac) does not appear to have his hands on the weapon.
bbrowniii
I used crumbled up aluminum foil for the water. Your right about the hand of the gunner I fixed it
Thanks
Mac
Hi Mac,
You can make the water look about 1000 times better if you get a product at your LHS called: Clear Parts Cement and Window Maker, from Testor’s, part No. 3515. How to: Squirt a small amount into a spray paint lid and using a big paintbrush, apply it liberally to everything that’s suppose to be water, including the explosion. Add more to the lid as you go until you’ve covered everything. It has a milky color, but will dry crystal clear and give the water a nice “wet” look. Also, brushing some on the vehicle above the waterline imitates wet areas where the water has splashed.
It’s a cheap, easy way to get realistic looking water. [Y]
Take care,
Frank
