hey guys i’m planning on doin some lah figures at rest and i was wondering what is the best way to paint pea pattern camo on 1/35th figure
thanks guys [8]
panzer_grenadier, start with the overall base color usually a light sand color, then paint the large green pattern areas, followed by the large red brown pattern areas. Then paint the dots using the same three colors over the base colors, if you wish you can add a little white to the base colors for contrast and variation.
It really helps if you have a photo of a pea pattern uniform to use as a reference while you are painting this type of pattern.
Hopes this helps.
there was an old thread on painting waffenSS camo uniforms.
edited:
oh wait, wrong forum… http://www.wwiiscalemodels.com/cgi-wwii/ultimatebb.cgi?ubb=get_topic;f=149;t=000001
I would agree with South Aussie’s comments and would recommend painting the uniform with the base color first (I typically use Humbrol #29) and then use your other pattern colors after the base coat is dry. Again, I prefer to use the Humbrol line for this as they seem to show few brush marks, and by thinning them with a little CLEAN Testors Brush Cleaner, you can paint very small dots. For the pattern, I would recommend using the smallest brush that you can lay your hands on, especially as you are woking in 1/35 scale, so preferably a 20/0 or smaller brush. This is just one method recommending one brand of paint, but it works for me, good luck with your figures.
Bull [oX)]
thanks alot aussie and bull you guys have shown me the light
so thanks again im really greatfull for the info you guys have given me
thank AZ[8]
