That’s a cool project! Unfortunately, your photo didn’t come through. If it’s supposed to be a link back to the image, it fails with error 404 (file/directory not found)
As far as supplies are concerned, if you plan on scratching the radome, I would use styrene card and 2-part epoxy putty. Cut the card in the shape of the profile, and glue the pieces together. Then apply the putty over the card framework, and sand to shape.
I’m sure others will have better ideas. But that’s how I’d do a shape like the radome
There are several other possibilities here… One ould be to try to carve a master and then vacuform off of it… But many modelers like our Don Stauffer say why bother - they propose just making a clean carving out of good wood, priming, painting and using the wooden part in the model.
Of course this is XXIst century, so using some modern technology like a CNC router or a 3D printer also is a viable option - if not for the final product, then for a half product or a jig.
Hope this helps - good luck with your build and have a nice day
Might try the bread and butter, gluing layers of styrene sheet to get the thickness needed. Carve to rough shape with a Dremel or files, then sand to final shape. Going to be a process without a sample to go by.
I would recommend carving it from basswood. It has a very fine grain so it is easy to prime and fill with a sandable primer- I use Rustoleum. It is also easy to carve. Both Micheals and Hobby Lobby carry basswood.
As an alternative, the oven hardening clay or epoxy putty are okay, but I prefer the wood. Sanding with a medium grit makes small correction in shape easy with wood. Hardened clay or cured epoxy are not sandpaper friendly.
Don beat me to the basswood recommendation…but in the past I’ve even used solid balsa or laminated balsa sheet, saturated with CA and then covered with putty for a final coat to sand smooth. Worked a treat.
(Oddly enough it was for the same radar, though on a different a/c, the early-warning version of the Navy’s wide-body Skyraider.)
In my case, the laminated balsa was scrap 1/8-inch sheet left over from whatever Guillow kit I had most recently built. Attached to the model with acrylic adhesive…essentially bathtub caulk, simply because it was what I had handy. Easy to ‘fiddle’ the piece into proper position, and it wasn’t going anywhere once it set up.
That is why I do not use balsa. With basswood one or two coats of a good primer and it is ready to paint. I have used Alclad over wood parts, and my friends could not pick the wood part from the plastic ones.
Heres a thought- the 1/48 ESCI/AMT AD-4W kit has that radar bulge. Get ahold of that kit, use the kit part as a master to mold one in resin for your PB. Or just pirate the radome off of the kit and build the AD as a different version.
It’s the same APS-20 radar, so the basic radome dimensions should be the same. They are built around the common APS-20 rotating radar antenna array. The main differences will be the contours of the attachment area to fit it to the different airframes.
