When a modeler of Vac-U-Form kits gets their model, the chance of mistakes is very real. That’s the reason for patterns. They help you accurize the model, rather than leaving it to chance. Now that said, I wonder;
This BEARCO model I am working on for my client leaves me baffled by the methods they chose to use. For one thing the patterns supplied, don’t even begin to fit the various places they are supposed to be used in.
I am having to lay out the areas with a pencil on the bulkheads and decks by hand because either the patterns are by heighth too short by over half an inch or they are short on the linear plane by way more. I always thought that the patterns supplied would be correct or they WOULD TELL YOU, in the instructions to enlarge them because they are NOT to scale.
On many Vac kits I have buillt over the years, this notation has always been present. I wonder if this is part of the reason they did not stand the test of time? The idea of a specific ship type manufacturer, in whatever medium is unique in it’s own way. In Plastic even more so. In this scale especially more so. This is a very narrow niche.
I do believe at H.O. scale or 1/87 if you will, the importance of correct patterns is important for sure. I have built the older style passenger cars that were Vac-U-Formed and ALL patterns were to size or it was Noted, Very Clearly that you had to enlarge them to size. Not so this kit.
This leads me to believe this is the reason the original owner of this kit gave up on it! For me, Now, I am able to work around it, Only, Because of my education on the Engineering and Design of Ships. The Novice would be lost. Bad enough it has confused me!
TB, I love you like a brother, but you are whining. Modeling always has its sets of challenges. I once bought two aircraft kits from a seller, no instructions included as stated.
For the sake of economy, they threw both sets of sprues into a box together. Problem- both airfix and both the same color styrene. It happens.
Bill, had somewhat similar situation about 48yrs ago involving i think Monogram Cheyene attack helicopter that had instructions for either the Huey or the Cobra. used the box art that showed the Cheyene to help me put the model together. i don’t remember any mistakes in doing the model.
I don’t mean to sound whiney. I am just surprised that this particular niche of models has been so badly served. You and I know how to do this stuff, this did put me into a wee bit of shock. I began to understand why the Client then came to me.
I was just trying to make it clear that maybe, Web Site or not, that BEARCO is no longer serving the public!! And to be a little whiney over a historic group of ships, truly underserved is Shameful to me. I do love a challenge, Maybe if others are floating around out others might Not want to be faced with it!
Oh, and to further underscore the non-whiney aspect, that’s why I buy a lot of Ships, Cars and Armor at train shows. “They’s like a box of chocolates, You never know what yer gonna get” That kind of challenge I am up to. Remember when I told ya’ll about the plane I was gonna buy and the fella couldn’t find the fuselages for the two sets of plane parts and just gave it to me.Then when I got it home there was a bag at the bottom that had all four parts of the two fuselages in there,They were so clear we both missed it!
I have built several Vac Form aircraft kits and the fit was generally pretty good ,but they were from quality manufacturers such as Contrail,A model and Rareplanes.Never heard of Bearco but I think that they assume you are a pretty advanced modeler who knows how to overcome fit issues(you) .Glad to read that you are progressing nicely.
The more esoteric or less served the market segment, the greater likelyhood the parts will not match the plans or the actual thing. Or even fit. It’s one of those modelling axioms. Vac kits even more so.
I have had the displeasure aircraft kits that had wings halves of differing chord and span, fuselages of differing lengths, heights, width and cross section profiles and such, and never mind the poor fit.
We make do with what we have on hand. The vac modeller is especially aware of this. Most times it is better to fabricate your own bulkheads rather than trying to trim and fit the kit’s vague, blobby parts.
The fact is one of Passedownedness. There is a chance that the client didn’t know what was there. I inventoried the kit there were Glaring missing patterns and parts issues, right off the bat. I knew this going in. Now That said, the Kit is massive. There are draw marks on the hull from the Vac process. This was expected as I have dealt with this on larger Sailing and Powerboat kits.
I will admit I was caught unawares by the lack of and offsize patterns. The kits I have built and developed over the years have had these things in the size for the model’s size. Or at least they tell you, “patterns drawn at half scale-Enlarge to fit” I did not go into this without knowing there were repairs to be made. After all, How could I possibly leave lines of Dayports going downhill on the bow areas. She’s looking good now. And I decided to open seven hatches showing the Taconite inside.The Taconite being modified Coal loads from larg Rail Gondola loads.
This was done Because, if all the hatches were done closed I would’ve needed 1,025 little clamps of the style used to lock down the hatches. By opening seven and fudging a little I can get by with 200. The biggest problem? I have gone to Great Lakes Steamer sites and Museum sites, and can get NO good detail shots of hatches, or Wheelhouse details, much less the aft cabin roof details. Working obliquely is more difficult, because you sit sit and wonder ,“Well, is that part on centerline or port, oh, maybe Starboard side.” I want this to be as good as I can make it for him.
Yes folks, I am a worry wart! Remember this is making me pull up memories from 70 years ago, and them clouded by time! I will get there! NOTE= GENE, the BEARCO firm only did Vac Kits and those only were Tanker Ships and Taconite/Grain/Ore ships from The Great Lakes!
Yeah! This will be seen by a group of Model RailRoaders that tend to build to the History of the Steel Mills and this Client/Hobby Shop Owner is a member of this group! He is very knowledgeable in Trains, not so much in Ships. He and His Missus are always welcomed with open Arms at our Train Shows. They are just all around great Folks!
