Parts of decals came off
I am building a ship, and had placed the decals on the hull. Afterwards I had given the hull a shot of Testor’s lacquer Glosscote to seal it and prepare for futur weathering. This was several weeks ago. This past few days I masked off the hull, using 3M blue painters tape, in order to paint the decks and superstructure. When I took off the tape, it lifted off some of the decals, and partially lifted off others.
Questions: Would applying more coats of Glosscote, or something else, prevented this, or should I have just waited to apply decals?
How can I remove the remnants of the decals without removing the paint?
Finally, since the tape was able to remove the decals (with a coat of glosscote on them) will weathering (using thinned enamels and artist oils) destroy them as well? Is there something else I should use to seal the decals?
Thanks for any suggestions.
Ron W.
Bottom line is keep tape away from your model after you’ve decaled it…
Since tape removed parts of the decals, that’s the tool I’d use to remove the remainder… As for lifting paint, you’ll probably just have to take your chances, but I’d try soaking the model in soapy water first…
As for weathing with oils or enamels, they shouldn’t destroy your decals… Just make sure that you give the model a coat or two of clear acrylic beforehand…
Thanks Hans. Honestly though, I thought the Glosscote would have protected the decals. I’ll use the tape, this time on purpose.
Ron W.
