Is it too late to get in on this GB? If it’s not too late I have an old Dragon Panzer IV/70(A) that I’d like to do.
Dupes-thanks for your tips on the tool painting. Good idea on the post-it note and the use of Blue tac.
Yeah, I remember the T-34…I ended up repainting it after your GB…still a winter scheme though. My first experience with indy tracks…snip, snip, file, file, snap…well, not really a snap…glue…curse…sigh…looking forward to the next generation Magic Tracks in this kit. However, the fact that there may be very little track exposed makes me think about using some rubber band tracks from a Tamiya Pz IV I have in the stash…time will tell.
Status reports-wheels are done, working on the lower chassis now.
Eric,
I think you’re talking about the SdKfz 7 series which are a bit bigger. This kit is brand new, and smaller. Here’s a pic:
Ben,
Nice work so far. Yes, I started my Marder III on Tuesday. Got most of the hull built, and now I’m going to concentrate on the Friuls I just had sent from Sprue Brothers.[:D]
Nate
[bnghead] Doh Nate. I can’t keep track of all of them. I didn’t know this was even available yet.
Ogrejohn, welcome aboard. Glad to include you and your build.
Nate,
Have you tried your Friuls yet ie assemble a length of 5-10 links and see if they are tight in the idler and drive wheels?
I’ve had another look at mine and they are tight but I think they’ll be ok. They were far too tight to use on my Hetzer but are a bit easier on this Marder III so I’ll give them a go. They came supplied with a pair of Friul 38t Drive Wheels and were too tight for them.
I’m planning a Marder II ‘Coal Thief’ build (I think it’s a Marder II) like the brilliant one that Andy Deafpanzer built in the Marder Madness thread and another Hetzer too so I’ll have use for any unused sets of tracks.
Anyway, let me know how you get on with your Friuls [Y]
ATVB
Ben [t$t]
Ben, I’ve heard of others that have cut down the teeth on the sprocket that would come into contact with the links. You might try that.
Bob - Agree with the others about the tools. I have done them both ways but find it much better to paint and put the tools on seperate and last, before weathering.
Ben - Nice to see you start up and looking forward to more.
Dupes - Have you started the STURER EMIL yet [:P]
Progress report:
After a long swim this am, coffee with some friends, a nap during a Premier League Soccer match on Fox, I started on the Jagdpanzer. First pic is of the road wheels (yeah, pretty exciting, ain’t it?), a pic of the front hull with some tabs that need to be removed (not called out in the instructions), some miss numbered parts but it’s all good. Lower chassis is together, wheels are not glued on…a little rubber cement will handle the track building process…but I’m done for the day. Will probably finish the Dora for the Reich Defender GB tomorrow and work on the Jagdpanzer from that point on.
I’m impressed with the quality of this kit, detail wise. However, the instructions are lacking (typical Dragon) and a lot of parts are a bit too complex, especially since they will be hidden (by road wheels, side armor…you know, that schurzen (sp?)stuff, etc)
Anyway, I’m ahead of where I thought I’d be so it’s all good.
Cheers
Eric: No worries, it’s hard to keep up with all the different equipment the Germans had. That’s why I like modeling them so much![:D]
Ben: I just finished a length of Friuls, and tried them on the sprocket. Yes, they are tight, but they do snug down. I think Eric’s tip about filing down the sprocket teeth will work to help the fit.
Bob: Nice work on your Jangdpanzer. I built this kit last year, and I don’t think I’ve ever had a more trouble free build.
Nate
Thanks Nate. Coming from the ‘wingie thing’ side of the forum, I’m not used to the number of parts to build a sub-assembly…well, maybe with the exception of the Accurate Miniatures Avenger that I built a few years back.
And I’m out the gate…
Like to start my builds of with alittle history
The Panzerjager I (47mm Pak(t) Pz.Kw.I-B) was the first German tank destroyer. Introduced in 1940 and used during the campaign in France also later used in initial operations in North Africa and in Russia starting with operation Barbarossa. Was armed with a Czech 47mm Pak(t) 36 L/43.4 (Skoda 47mm A-5 P.U.V vz.36 gun), operated by a crew of three and built on a PzKpfw I Ausf B’s chassis. The gun had a limited traverse of 15 degrees and the vehice carried 86 rounds of ammunition. The vehicles proved inefective and rapidly disappeared because of their inadequate fire power, although some remained in service as late as 1943.
Decided to start with the interior. Parts have nice detail and fit good. The ammo boxes and transmission assembly are just dry fit and waiting for paint.
Plan on painting the interior white / cream and the transmission assembly dark green. Plan on painting all of the interior the cream color up to were it would have been the base of the turret. My question is this correct being tht it is an open top?
Also cleaned and preped almost all parts for the susspension. Did not feel like playing around with the wheels tonight so just baged them with there part # in the bag.
Now it’s off to paint.
Good progress Rob. I like how this little tank hunter looks, and can’t wait to see what you do with it![:D]
Nate
Bob,
You picked a real good kit to build if you’re used to aircraft. I had it built in no time, and with zero filler. I remember that about the hardest part was applying the casting number to the mantlet.
Nate
Dupes it’s great to see you back in action, if its not too late I’d like to vote for the sturmer Emil.
Well JUst to prove I have not forgotten theh build heres my kit, I hope to start during the week,
Good luck to everybody involved on this great venture,
Terry.
Great start Rob-looking forward to paint and more progress pics.
Rob, that little guy has a heck of an interior. I haven’t opened my box yet, so i haven’t seen the goods.
Bob, way to cut loose and start building those darn wheels. I haven’t seen this kit built up yet, so I look forward to it. It was the latest to find it’s way into my stash courtesy of Spruebrothers. Are you building yours with the schurzen?
Terry, I saw the Marder built up at a show and was impressed with the detail on something so small.
I didn’t get much done today, a little apathetic. I might be falling behind my planned schedule. If all goes really well, I’ll be painting the base a week from this sunday.
Thanks Eric. I haven’t decided on whether to build it with the schurzen or not. With would be a great way to hide any issues with the road wheels/tracks. However, the kit schurzen are almost ‘too nice’-I prefer a little ‘wear & tear’ look. I might look into some PE schurzen or just build without. I hate the complexity (usually) of PE items like that. Or maybe just separating the the panels and/or a thinner scale plastic might do the trick…we’ll wait and see. And I’m always open for suggestions.
Hey guys,
Some lovely looking builds,
Bobbaily - That Dragon JP will sure be a fun build and will make a great model. I have to agree with you about some crazy over-engineering (my Marder III M is the same) but complex builds is Dragon all over! You’ll love it!
Panzerwaffe - The Panzerjager will be one to watch. I have in my display cabinet a Dragon Panzer I Ausf A with interior that is a personal favourite of mine - some of my 1/48 builds are bigger than it! I also have The Panzer I Ausf B which is obviously the chassis your PJ utilised. I had a 'mare of a time with that kit (all problems of my own doing mainly) but you might find the running gear assembly a PITA so take care. Are you planning a super detailed drivers compartment? It’s practically the same as the interior on my Dragon Panzer I Ausf A and that was great fun to build and paint.
Terry - The Tamiya Marder III in 1/48! Nice - I built this in 1/35 scale and it wasn’t a big vehicle so I’ll look forward to seeing what you can do with this one.
I’ve been looking after the work phone all morning but it’s been dead so I’ve assembled one full run of Friuls for my Marder III M and got paid to do it [Y]
I’ve also looked at some of the parts for the Marder. Dragon really moulded this plastic so well, it’s super detailed and the compartment walls are super thin to scale like they should be and not nasty & chunky.
I’m dropping the work computer to a colleague on the other side of town now - when I get back I’ll start with the Marder engine assembly.
ATVB
Ben [t$t]
Whoah, I hit the bench all night (forsaking the forums) and everyone is building like mad! Some good looking stuff going on. [Y]
Terry - not too late to vote at all! I’m going to try to give everyone a chance to chime in…I won’t be able to start in on the Sturer until the end of this month, anyway, after Downeastcon and Valleycon. So let’s say the voting deadline is the 11th of March - that way I can scour the vendors at both shows for additional aftermarket goodness.
Tigerman- Jagdpanther
Panzerwaffe- Sturer Emil
Bufflehead- ???
RMC_Birdunner- ???
Big Smitty- ???
Wing_nut- Sturer Emil
Bobbaily- Jagdpanther
TigerEp1- ???
Nachtflieger- Sturer Emil
Terry35- Sturer Emil
Hinsky**-** Dicker Max
Dupes__- (tiebreaker)__
bbrowniii_-_ Jagdpanther
Wolfp - ???
ogrejohn - ???
So the Sturer currently leads with 4, Jagdpanther at 3, The Dick with 1. Panzerwaffe, looks like you may be right!
