Pak40
Hey
I’m building a Pak40 for the towed group build and I’m looking for reference pictures. Does anyone know where there are some pictures of camoflage… that I could use.
Thanks
Mike,
The best piece of info I have for you is to check out any book on the battle of Kursk that has alot of pictures. On book I have “Kursk in Pictures” has a couple pictures of them in it but cant remember whether or not thay are any good. I’m not home right now but when I do get home I will post again with the books that I do have that have a couple decent pictures in them.
Rich
Michael
Most Pak 40’s were monotone - gray or yellow. Paint was not an item usually issued to Pak 40 gun crews, only the occasional gift of Whitewash. These guns were quite often towed by trucks, not just halftracks (as the latter were far more expensive than trucks and were required for other duties) and trucks were not issued camo paint.
Due the limited supply of paint granted for use on the other vehicles used to tow them, the gun crews relied on ground cover, bushes, reeds, branches, etc to break up the guns outline. When they did camo, it was from paint ‘acquired’ elsewhere, and the pattern was whatever they felt like doing and usually limited to only the barrel and gun shield.
But hey, paint it what you want - there were exceptions to every rule.
Shermanfirefly, Here is link to some refs. Its more for detailing rather than painting. But I hope it helps…
http://www.panzer-modell.de/referenz/in_detail/pak40/pak40.htm
Thanks for the help. The link helps out a lot Kenneth.
Shermanfirefly, My apoligees. the book I told you about doesn’t have as many pictures as I thought. as a matter of fact it had none in the quick glance I took thru it. It is however a great reference book for both german and russian armor as far as picture content goes. The book is called “Images of Kursk”. by Nik Cornish
