I have read alot of posts about painting tracks, but the tracks that come with my M-3 Stuart by academy have abasically flat bottoms, no details except on the sides. So do I just do a base color and drybrush the sides or do I do something else with the flat pads that contact the ground? sounds like a silly question but I am confused!!![B)]
That style track had a rubber pad that contacted the ground. I simply use flat black for the pads.
Derek’s got this one bang on the money. Think us each track shoe as a rectangular block of rubber, paint all of that black. The end connectors are the visible steel part in those style of tracks. These are what you want to paint with metalic colours.
Tracks and track shoes are a real conversation starter. Yes, the Stuart track you’re modeling had rubber shoes or pads (called blocks in WWII). The end connectors (WWII… Links) were steel. Anyhoo. A track will pick up a lot of dirt even on pavement and start varying away from a pure black (Unless skidding around a turn). A clean track shoe will be anything from dark gray (clean) to brown or tan to light sand depending on what the tank is running through. Once on a harder surface, pavement or even harder ground, grass, this ‘mud’ tends to wear off quickly, with the color only around the edges. So, you can paint the tracks black, wash the tracks with a lighter color and then wipe off the bottom of the shoes where it contacts the ground to give it depth.
The links (WWII), or end connectors (now), will be shorn of rust in a fairly short time and will become steel colored with sand, mud or what ever stuck to them. So, a base of (dirt, sand, mud) color with steel highlights looks nice.
This past weekend, we ran Paladins through wet sand. The shoes became steel colored with sand in the nooks and crannies, while the pads were gray black with lighter gray side areas. Where the track guides meet the road (bogie) wheels, they were rubbed to a high shine, as was the wear plate on the wheel.
The track on an opperating tank is seldom rusty, unless the vehicle has been sitting for a long time… then it tends to be light (orange) rust. The mud and grime really add character to an otherwise dull steel track… on a running tank, that is.
Sorry, didn’t want to write an article… next time ‘live’ vs. ‘dead’ track.
You have a lot of latitude with tracks, so have fun!
And it was just getting interesting Poniatowski … I can hardly wait for the sequel.
And… can you believe that assembling and painting the tracks is my least favorite part of putting together a tank model?
