Anyone have any tips for painting multi-coloured spinners? I’m thinking specifically of the Normandie Niemen Yak-3s, which were red, white and blue. I have the Hasegawa one, and I’ve struggled to mask an even line all the way round on models before, and this one has two demarcation lines. [V]
if you want the painted look find a decal to match, put on the decal, and take a fresh razor and cut off a strip at a time and paint it ,save the strip because youll need to put it back on to keep it masked, try that. if you find a better way please post it, ive been having trouble with that as well and ive just been experimenting on the best way to achieve that look.
Keith -
Sounds like a pain, but I’ve had success using clear decal film - just paint the film the same color as your spinner, cut an extremely thin strip, then place that around the spinner in the correct location. This way, you have a hard color edge that you can mask against (use low tack tapes or post it notes) to paint the rest of the spinner.
Works for me…
I use the drill! Put the spinner on the toothpick/tape. And when it running your drill then put the brush on with whatever paint. I hope you understand. [B)]
If you are talking about front, middle, back, go to an office supply store and get a circle template in inches or millimeters. Paint the whole spinner the middle color. Find the appropriate whole for the back line and spray the back using the template as a mask. Repeat the process for the front color. If you are afraid of bleeding under the mask, cover the hole with maskikng tape, and cut it a little smaller than the hole, so it creates a tighter seal. Is this the question you are asking?
Thanks for the replies! I don’t much like using decals, but I’ll definetly give the last 2 methods a shot. Love the idea of using the drill like a lathe - why do I get the feeling that’s gonna end in tears tho…[B)] Still, your Il-2 looks ace, well done.
Try spinning the propeller with a hairdryer or something and then paint the strip with a brush. This Ju-87 is motorized but all you need is to get the prop spinning.
B.
All those hand painted china plates and pots have their various bands and rims done by spinning the pot and applying the brush for a couple of seconds to apply the paint. By spinning the spinner and applying the brush you should get a perfect centre band with just a couple of seconds work. the width of the band will depend upon the width of the brush, the amount of paint on it, and the pressure applied. With a little practice you should get a far better result in a fraction of the time and effort than trying to mask and spray it. I think that some people get so addicted to spraying everything in sight that they sometimes forget that this isn’t always the best way.
