painting problem help
I airbrushed my model, model master enamel light grey yesterday and today I found that it had many little shiny spots on it. Please Help
Hmmm. Several possibilities here. Did you wash the kit plastic before you painted? Was the paint adequately thinned? Could be one of those issues. Best advice is to lightly sand those areas with extra fine wet-to-dry sandpaper until the spots have disappeared: make sure the paint has thoroughly dired first!!! Recheck your paint viscosity, your compressor psi settings(<20 psi) and retouch the kit. Hopefully there won’t be a repeat of the problem. Hope this helps.
