Painting Eyes on Figure (54 MM) ??
Hi All,
I am a brand new member of the Fine Scale Modeler forums and also brand new to figure modelingt. My model subject has a human face and I wondering if someone could direct me to a website(s) that shows pictures of how to paint eyes. I have some good resources regarding face painting but for eyes…nothing.
Thanks
Stretch5
Stretch5…I had the same question a while back…here is the link to an article that may offer you some help…it was given to me once and i found a lot of helpful tips…
http://www.finescale.com/fsm/default.aspx?c=a&id=1481&mid=18594&auth=d477bb765c112ddb6922108513243cb2e61d089aa76ae438ddd5fe79b9889c0a
Mary
Stretch,
Painting the eyes is always a challenge. In fact modeling figures is always one of the most difficult parts in building models. I know Paine Sheppard’s building dioramas book has pages dedicated to the topic…His stuff is available through Kalmbach publications.
When you paint the eyes, I find it helpful to follow a few steps…
First, start with white and paint the almond shape areas where the eyes will go.
Next, take the color for the iris and paint that spot in the center of the white area depending on where the figure is looking. I find using a pinhead is useful for positioning the iris. Other techniques show painting the center with the eye color, then touching up around it with white. Either way works.
After you have the white and the eye color, take out your white and touch up around the eye color making sure the iris is in scale to your figure.
Finally, use your skin color to touch up around the white parts shaping the eyes as you want them to appear. Not too big nor too small.
A great brush as small as 00 might be necessary. I find working with acrylics is easier because the drying time is much shorter…however…for deep, rich color you might have to use oil or enamel based colors.
These techniques are all outlined in Shep’s books and there was an article in finescale as well…If I come across an internet site I’ll let you know.
the key is to be patient and not try to be perfect each time…work neatly and realize small touch-ups are necessary to make it ‘perfect’…avoid working or touching-up until the area is completely dry to avoid paint build-up or caking up…this could ruin your finished result.
Good luck with that,
Tank
Hey Tankbuster great advice I’ve done a few figures and never even thought of using a pin that one I am definitely going to try cheers for that !
Tony
I have found that the amount of paint on the pin is very difficult to get correct. If you have too much it doesnt turn out right and looks like crap, and if you have too little nothing will go on the figure. If you think you have too much, wipe it off and try again before you screw it up.
