Painting an F-18 from FSM magazine May issue
Hello everyone
I bought May’s issue of Fine Scale Modeler and noticed in the article for Carrier-Deck Diorama.
It has a picture of the F-18 which you can see here.
http://picasaweb.google.ca/lh/photo/Qif6D-yEg2JmzrtxrGILcyVZO9TKqWSmXGHG9BmT-r8?feat=directlink
I like the basic shade of light gray all over, but then there are dark lines where there are panels on the fighter. If there were grooves in these locations I would say just using a pencil to show the panels.
However there are no grooves to run the pencil down.
Can you tell me the secret of how this is done.
Scott
Scott,
Whilst i can’t profess to know the exact answer, my suggestion would be to pre-shade those lines with a darker colour (how dark depends on the overall colour, eg, a dark gray under a lighter shade of gray), the same way you might pre-shade panel lines prior to painting.
Then paint over the top (you should be able to see a very faint outline of the pre-shade underneath).
Following that, and depending on whether you think they contrast enough, use some ground pastels on a brush and go over those pre-shaded lines, to make them pop a little more.
Hope this helps.
I’ll be interested to see anyone else’s tips too - perhaps I can refine my technique or even learn a new one.
Chris.
Thanks Chris
I will try it out
Scott
