Half a year ago I decided to pick up on my old hobby again. I’m 33 now, live in The Netherlands, and the last time I did armour modelling was when I was around 17 I guess… I’ve been reading this forum for some time now and am really amazed by what I see!
Anyway, I’ve just bought this King Tiger kit from Dragon: I love the camouflage pattern in the pic and am thinking of trying my hand at it. I haven’t got that much experience with it though, so I have a few questions…
What are your experiences with freehand airbrushing such a pattern? I have an old Badger 150 airbrush. Do you guys think this airbrush (with a ‘fine’ nozzle and needle) is able to do the job?
My previous kit was the Tamiya Hetzer. I wanted to give the camouflage a go and found some great masks from J’s Work. What are your opinions on such masks versus freehand? Does the hard lines camouflage add to the realism or just the opposit? They also have a mask specifically for this King Tiger, but it’s a bit different then the one in the Dragon manual, which I actually prefer…
Last question Which paints do you prefer for German WW2 camouflage? I’ve always used Tamiya (combo of Dark Green, Dark Yellow and Red Brown) but have read good things about ie Vallejo and Gunze. However I’m a bit confused which colours are best. I was thinking of giving Vallejo Model Air a try, as it’s specifically designed for airbrushing, but I’m not sure which colours would be used for this camouflage scheme.
Sorry for any typo’s/grammar, but my English is a but rusty Thanks in advance for any advice!!
I think most of your questions can be answered by saying it’s really personal preference. I think your air brush can handle the job with ease. I normally paint those patterns free hand and have no experience using the masks you speak of. I use Model Master paints, mostly because they perform well and are available at my local hobby shop. I haven’t tried Vallejo model air, but I do use Vallejo model color designed for brush painting and they are outstanding. Realism is often open to opinion as well. I generally paint soft edge camo unless my references show the vehicle in question painted with a hard edge scheme. That’s my two cents, for what it’s worth.
You can use free hand or if you want hard edges you can try silly putty. I know it sound wierd but it works really good. I would roll small snakes to get the dark yellow. I would start with that color as a base. Then apply the small snakes to cover the yellow that you want. Then I would go with the dark red and then make larger snakes to cover the red that you want and then paint the green. Also the silly putty will conform to the contours and doesn’t let any bleed under. Another thing it doesn’t pull up any parts. If you would like to see my example of this technique is my King Tiger in the First Big Cats GB.
I use Gunze and love them. Bad thing about them is you might have to buy a couple of different colars to find the one that you want to use. Also having to order them might be a problem at times.
I use a Pasche two stage brush, but I think your Badger will work.
