Hi all - I need a white “H” code letter for the fuselage on my Do17z. All I have on my decal sheet are black ones, and I can’t find any on the net.
Can I cut out the black one, paint it white, and then apply it to a curved surface without the paint cracking?
What paint should I use? The best white I have with decent opacity is Floquil’s reefer white. Would that work? Should I overcoat it with a clear before applying it?
Does any one know of a decal sheet of white German code letters, 1/72 scale?
While it may not work for everyone-- I had to change the blue/white checkerboard scheme on a decal to blue and black…being too lazy to mask all those diamonds, I just painted in the black…and it worked great for me.
I used regular ModelMaster Gloss Black acrylic for my decal…let it dry a couple days- and it went onto the nose very smoothly-- especially with some MicroSet and Sol.
You could also paint a white area, apply the black decal over the white area (dry transfer work best for this method, tho) - paint your camo. After it’s dry, take a piece of tape and dap the decal with the sticky side to remove it.
Here’s what I’ve done: use a straight edge and x-acto blade to lightly cut through the decal (not all the way through the backing paper, though). Then paint the decal, let the paint dry a couple of hours and apply as normal. I’ve done this successfully to change yellow 8th AAF codes to the proper gray. Usually I do the decaling as soon as possible after painting the decal, so that the paint stays somewhat flexible. I don’t know if the paint would crack if left to dry too long. I’ve used Model Master for this, thinned with DioSol and Glaze, both Floquil products, so I think the technique would work using Floquil paint, too.
First, try Verliden or Squadron. If you live near a graphic art supply store you can get the Letraset dry transfers. They come in a multitude of font styles and sizes.
In the meantime I’ve been experimenting with painting clear decal film. Biggest problem is finding a knife sharp enough to not tear the film. Even a brand new #11 won’t cut into or out of corners with the crispness I want, although for a simple “H” letter I can just lay it down in strips.
