I have a hard time painting small details in aircraft cockpits without messing things up. I don’t have the best paintbrushes in the world for doing the small detail work and am not really sure what to buy. Could I get some advice on what brushes would be good for detail work please? I’ve found that the Hobby Lobby brushes I get are pretty bad at keeping their shape (fraying) which makes painting even harder. I primarily use Testors and Model Master enamel paint.
One trick for really small detail is to use a toothpick. Those round type, sharp at both ends, are best.
Shake your paint bottle, take the cover off and lay it upside down on your bench. A thin coating of paint will be adhering to cap. Dip the toothpick tip into paint, then touch to model. You cannot draw a very long line without running out of paint, but the small amount of paint on the tip helps you by not letting a big gob of paint flow out onto model surface. So you paint by making a line out of a series of contiguous dots. This trick is really good for aircraft cockpits- lets you paint tiny switches and levers.
I am but a grasshopper compared to most of the posters here, but I am a big fan of Robert Simmons Sapphire brushes that I get at the local Michaels craft store. They are not cheap, but you get what you pay for. I have some Tamiya brushes that I like, and a set of very small (3/0, 5/0, 10/0) Atlas brushes that work well enough for my poor painting skills. As for fraying, you have to be very careful not to mash them and also try to reshape them when done.
There’s a great video on this site about how to clean brushes.
I will have to look at Michaels next time I go up to Denver. I have one of those brush cleaners I got from MicroMark which cleans them good but they don’t seem to stay in shape for long. Guess you’re right when you say you get what you pay for.
You also need to remember , You MUST reshape you brush after cleaning .That way the bristles will keep the original shape .
Don’t skimp on brushes .I just retired a medium round -Small that has seen fifteen years of continous use .The reason it got retired . Well , lets just say a model sailing ship is sporting the main part of the handle .
Check out micro marks online site. They have a wonderful selection.best part is,if you order from them,you will get their catalog for the rest of your life
Here’s a pic for size comparison. I use them a lot for paint touch up. glue application and clean up. I buy the 100 packs and treat them as diposables. Usually get em from Micromark.
Something I read that Shep Paine said has really stuck with me. The shape of the brush is more important than the size. A really good 0 or 00 with a very well shaped tip, is better than a 0000 with a bad tip. And if a brush is too small, it won’t hold enough paint to do much before it thickens and/or dries. And paint thickness needs to be right.
So, a properly shaped brush that will hold enough paint of the right consistency is the trick.
