paint thinning
can I use rubbing alcohol to thin Tamiya acrylic paint?
i would ask this in techiques/painting. i use paint specific thinner for my paints but that is because i have enough variables i can screw up without adding a new one.
I use iso 91 to thin Tamiya never have had a problem.
I like this. Same here
You CAN, but you’re better off using Tamiya’s own thinner for smoother finishes. Tamiya’s paint dries pretty quickly as it is; rubbing alcohol will only make it dry faster and possibly before it hits the model, depending on the temperature and humidity.
If you’re shooting gloss colors, try using lacquer thinner. Tamiya’s paint is actually a lacquer/acrylic hybrid, and glossy colors go on much smoother when you thin them with lacquer n.
