Paint Stripping
What can be used to strip acrylic paint after it has dried???
Castol Super Clean, or likely even Windex…
Murray
Where do I get Castrol Super Clean? Will it attack the plastic? BTW, I used MM Acryl.
You can also use Easy Off oven cleaner. You do have to keep an eye on things using any paint remover though, it will score the plastic if left on too long.
No, Castrol Super Clean will not attack the plastic.
You can even remove dried acrylics with Simple Green cleaner.
New tidbit of info to add to my collection … thanks Mike. [^]
