I find the battery operated Badger paint stirrer is to troublesome for Vallejo paint. I know there’s a product for Nail Polish Shaker or the Robart shaker. Both I find to big for there use. But I realised I have this in my tool drawer… https://youtu.be/0kATZftejxk
Neat, but does it not seem to take more time to use that, than it does to just shake the paint for 10 or 15 seconds? I suspect this would be neat for paint that has been sitting around for a long time. The more frequently used colors though, I’ve never needed more than a quick stir/shake.
I like to stir the paint instead of shaking it unless it’s Alclad which is very thin and mixes easily with a quick shake.
After using Vallejo for a while, and following their recommendation to roll the bottle between your hands for mixing/stirring, once I had emptied a bottle I removed the nozzle and examined what was left behind as residue. The remaining material was a huge amount of solids. Now I take the bottle nozzle off, very easy to do, just push it a bit sideways to lift an edge at the seal, a dull blade or fingernail then will fit under and lift it the rest of the way off. No damage to the nozzle or bottle, remains fully serviceable.
Then I have access to the interior, for a complete stirring with whatever will fit inside and go to the bottom. I can tell how well all of the ingredients are blended, by periodically looking at what is still gathered at the bottom of the stirring stick. Once it’s all mixed I put the nozzle and cap back on, then give it a good shaking for several seconds, to complete the process.
If I recently used the bottle, (2 or 3 days,) I do think it’s OK to shake for mixing, any longer and I repeat the stick stir method. A DuPont rep once told me, paint is a “system,” designed to work as intended ONLY if instructions are fully complied with. The DuPont Imron Polyurethane paint has emphatically clear instructions on the label, "MUST BE THOROUGHLY STIRRED BEFORE APPLICATION. It was clear to me that if you don’t get it all right, you’re not getting all that you paid for.
If you feel like trying it, shake a bottle of Vallejo well, then remove the nozzle, stir it around for a few turns, check the stick and see what is balled up on the stick end. Vallejo works much better for me when I do a complete stir. Takes a little longer, yes, but I think well worth the time.
Patrick
I had a cheap battery operated stirrer from Micro-Mark. It worked a short time until the cheap switch failed. So I took the stirring tool out of it and put it in my Dremel moto-tool. Works absolutely great that way. Threw out the rest of the MicroMark motor handle, switch, and junk.
Patrick my method before the Mini Sander is thorough stirring also.
But I use the non slip rubber mat to pull the nozzle. Then use my Badger paint stirrer.
I guessed I still need to do this for those bottle unused for months.
I dump the whole bottle out into a cup, scrape the crud out of the bottle pour it back in. Unfortunate but the state of the hobby now tends to put old paint on the market.
